![]() | Home > My Defender > BeaTie |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11096
| Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5378
i should have been an auto sparky, a few weeks ago i lost my full beam, and i was suspecting that the pink relay had died and possibly the yellow one from in the fuse box. , lucky enough i had a spare ones from the metros. Turns out things those were ok regardless, but the pink one i think was on its way, as it liked to make a noise and no lights would come on. That was after i changed the light switch, which i thought was causing this error. Anyway i have broke up and used my spare time off there to have a look at things more, I have ordered off a proper stalk, as that is damaged anyway. Bought a proper unit no cheap crap. I decided rather than pull the full nosh to pieces, i thought id just plug in and go from there. Plugged things in, and even a replacement bulb. I decided to disconnect the 3rd party loom, and sure enough the full beam came back on. So had a look at the loom, and i found that water had killed a relay. so one i removed from the fuse box, went in and all is well, and i have relocated the relays to stop things from going west again. Just as well i didn't replace anything further, as i was called out to rescue my dad. Brakes again! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Mam has had her 1st test drive out in BeaTie there, put her on the insurance, as i am suspecting another wild ride here again
You might have a hard time getting Beatie back
your not wrong there
the splines on one of my wipers are starting to fail sadly, the wiper itself didn't move. My work mate was ill with laughter at me trying to tighten the nut, to see if the wiper arm would bite on the splines. Which it did lucky enough. So i decided to go for a little bit of a face lift, which came and also i bought replacement arms too if needed to revert back, I will get deploy the face lift at some point. But i cannot see it happening this weekend, as i will have to help get Terr back in action. I am been a Taxi at the moment, not like it bothers me, but its costing my mam bus fare and she is wanting to be away by the time i am getting up for work. ( she doesn't really need to be there at 5.30 ) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
well today i decided while the weather was warmer, I decided to change the wipers over, and top up the juices.
The way my dad had put the wiper on the driver side was a joke, which i have now sorted with the new upgrade Click image to enlarge Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
It defo looks higher to me
| Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 604
So I had those "smooth" arms, love the look but just couldn't get good clearance on the screen and put it down to them not applying enough pressure. How do you find them?
I found the pressure is the same compared to the old units, but the wiper blades seem better than the bosch units. i am pretty sure these are some sort of common rear wiper, like off a clio or a toyota. The metro lads used to change the rear wipers on metros for the Clio,
another upgrade just been bought there, I will be fitting a soon as it arrives.
for the very 1st time, Beatie here failed her MOT
I have been britparted, the rear damper blew its oil and the backbox has more holes in it, than the days of the week Bilestine or how its spelt are going on this time. In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Not good but your able to get her through the mot soon with all the new parts
looks like the rear anti roll bar has seized, which will explain the rear damper failures on one side. Ordered off new drop links. She had a her new mot on thursday night. Mot tester was happy enough to see the exhaust and dampers on the car
| All times are GMT |
