Home > My Defender > BeaTie
Page 28 of 29 <123 ... 272829>
Procta
Beatie had a vibrating noise at high speed, and guess what these fools didn't do the gear stick up tight enough, so a quick nip with the spanner Rolling Eyes I am like are you serious! so it wont surprise me if something else goes wrong with her, But they are dealing with me. Andy here will have a few strong words if things do go wrong Thumbs Up Some one might get hit possibly Whistle and it wont be me Thumbs Up
Moving onwards, i have ordered a new gear knob, the other one has seen better days, and i am sorting out this plastic cam cap crap, as i am suspecting the rear one has gone. Thumbs Up Still need to replace the binnacle this one has failed again, ( britpart ) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #1051875 16th Nov 2024 2:57am
L110CDL
Rolling Eyes Thumbs Up Clayton.
Keeper.
Post #1052335 20th Nov 2024 8:54pm
Procta
i should have been an auto sparky, a few weeks ago i lost my full beam, and i was suspecting that the pink relay had died and possibly the yellow one from in the fuse box. , lucky enough i had a spare ones from the metros. Turns out things those were ok regardless, but the pink one i think was on its way, as it liked to make a noise and no lights would come on. That was after i changed the light switch, which i thought was causing this error. Anyway i have broke up and used my spare time off there to have a look at things more, I have ordered off a proper stalk, as that is damaged anyway. Bought a proper unit no cheap crap. I decided rather than pull the full nosh to pieces, i thought id just plug in and go from there. Plugged things in, and even a replacement bulb. I decided to disconnect the 3rd party loom, and sure enough the full beam came back on. So had a look at the loom, and i found that water had killed a relay. so one i removed from the fuse box, went in and all is well, and i have relocated the relays to stop things from going west again. Just as well i didn't replace anything further, as i was called out to rescue my dad. Brakes again! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1055465 23rd Dec 2024 6:59pm
Procta
Mam has had her 1st test drive out in BeaTie there, put her on the insurance, as i am suspecting another wild ride here again Rolling Eyes She has sort of taken to her as a duck to water to a certain point. She has had to get used to a different gearbox and throttle pedal. Due to her going from a 200 TDI to the TD5. lucky for me i got the electrics sorted out isnt it Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1055492 23rd Dec 2024 10:24pm
L110CDL
You might have a hard time getting Beatie back Whistle Clayton.
Keeper.
Post #1056010 31st Dec 2024 9:28pm
Procta
your not wrong there Laughing looks like she will be using her for the rest of the week, looking at the parts coming in. The clutch on the 306 is on its way now sadly. Crying or Very sad Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1056034 1st Jan 2025 12:11am
Procta
the splines on one of my wipers are starting to fail sadly, the wiper itself didn't move. My work mate was ill with laughter at me trying to tighten the nut, to see if the wiper arm would bite on the splines. Which it did lucky enough. So i decided to go for a little bit of a face lift, which came and also i bought replacement arms too if needed to revert back, I will get deploy the face lift at some point. But i cannot see it happening this weekend, as i will have to help get Terr back in action. I am been a Taxi at the moment, not like it bothers me, but its costing my mam bus fare and she is wanting to be away by the time i am getting up for work. ( she doesn't really need to be there at 5.30 ) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1056999 11th Jan 2025 2:50am
Procta
well today i decided while the weather was warmer, I decided to change the wipers over, and top up the juices.
The way my dad had put the wiper on the driver side was a joke, which i have now sorted with the new upgrade Thumbs Up i think passenger side wiper is still a little higher up, but then again it might be how the photo is.
Post #1058038 20th Jan 2025 8:36pm
L110CDL
It defo looks higher to me Wink Clayton.
Keeper.
Post #1058071 20th Jan 2025 10:25pm
Stiff1
So I had those "smooth" arms, love the look but just couldn't get good clearance on the screen and put it down to them not applying enough pressure. How do you find them?
Post #1058474 24th Jan 2025 5:08pm
Procta
I found the pressure is the same compared to the old units, but the wiper blades seem better than the bosch units. i am pretty sure these are some sort of common rear wiper, like off a clio or a toyota. The metro lads used to change the rear wipers on metros for the Clio, Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1058484 24th Jan 2025 6:34pm
Procta
another upgrade just been bought there, I will be fitting a soon as it arrives. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1058487 24th Jan 2025 7:06pm
Procta
for the very 1st time, Beatie here failed her MOT Big Cry
I have been britparted, the rear damper blew its oil and the backbox has more holes in it, than the days of the week Laughing All items i fitted not that long ago Shocked
Bilestine or how its spelt are going on this time. Thumbs Up polybushes are ordered off too, so its going to be a case of rolling the package on, as i need her for work, The 306s clutch is making some mega noise after my mam ran it for a year Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1060574 14th Feb 2025 7:48pm
L110CDL
Not good but your able to get her through the mot soon with all the new parts Very Happy Clayton.
Keeper.
Post #1060883 18th Feb 2025 9:50pm
Procta
looks like the rear anti roll bar has seized, which will explain the rear damper failures on one side. Ordered off new drop links. She had a her new mot on thursday night. Mot tester was happy enough to see the exhaust and dampers on the car Thumbs Up Also he knows someone who can re new the rear cross member on her too, so that will be done at some point this year. Once i can get the 306 back in action. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1061193 24th Feb 2025 6:50am
