Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 107 of 111 <123 ... 106107108 109110111>
Retroanaconda
emariu wrote:
@ Retroanaconda Can you please be more specific about the section you find this reset interval in?
It’s under the ‘Service/test’ menu.
Post #1056630 8th Jan 2025 9:09am
Retroanaconda
DrRob wrote:
How often do you change the oil in your L663?
I do my own oil/filter change every 10k miles, so roughly halfway between the official ones. Its next official service is the 105k one so that will be done at a garage to maintain warranty but once that’s finished I’ll do it all myself.
Post #1056631 8th Jan 2025 9:13am
emariu
Romania
Thanks, I'll check it later
Post #1056636 8th Jan 2025 10:02am
Emtroulis
Australia
Hi All,
Would you please help me set up the cruise control to increase 1 Klm and no 2?
Thank you in advance.
Post #1056855 10th Jan 2025 12:52am
BobP
United States
Does anyone know if the Sirius radio option is installed on the US models from the factory and just needs activated in the CCF files or if it would need a different radio set up? I did see it as an option on EUCD-119/EUCD-125
Post #1057214 13th Jan 2025 3:34am
bear100
so I'm kind of hooked and wanting to buy one!
but what is there to unlock on a 2023 V8?
is pretty much all of it unlocked on these models? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1057219 13th Jan 2025 8:31am
Colin68
Chauffeur mode
I see hunters prestige now offer chauffeur mode activation for the 2024 defender. Does anyone know how to activate this using the G4?
Post #1057314 13th Jan 2025 11:18pm
Colin68
Chauffeur mode
Post #1057315 13th Jan 2025 11:18pm
northeye
Japan
MultiCAN-665 ChaffeurMode
Fitted
MultiCAN-853 TS Sec Seat Movement
Touch Screen Control of Secondary Seat Movement - Fitted
Post #1057318 13th Jan 2025 11:45pm
Colin68
The_75th wrote:
pjeski wrote:
Might be worth trying:
MultiCAN-878 Corner Speed Adapt
Tried this one - no change that I could see.
Did anyone get anywhere with this?
Post #1057425 15th Jan 2025 8:33am
DefenderMidlands
Service/Test -> IPC-Instrument Pack -> Service
Interval Reset .... MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1057426 15th Jan 2025 8:48am
malibu
Australia
Corner speed. Did anyone get a new menu item?
Country road assist incorporates two features to reduce the requirement of driver interaction with the adaptive cruise control system. The country road assist features are:
Corner speed adaptation – the feature identifies and reduces the vehicle speed to a comfortable value if the current cruising speed is too high for an upcoming corner.
Speed limit adaption – the feature identifies the upcoming speed limit and updates the adaptive cruise control set speed.
The country road assist features can be enabled and disabled via the touchscreen as follows:
Touch the settings icon¹.
Select Vehicle.
Select Driver Assistance.
Select Cruise and Limiter.
Select Adaptive Cruise Control: Speed Assist.
Select Corner Speed Assist to enable corner speed adaptation.
Select Speed Limit Prompt to enable speed limit adaptation.
Post #1057621 17th Jan 2025 4:10am
kenl
Australia
Interval Reset ....
I have just tried this but IPC Instrument Pack is not listed? L663 110 D300 MY23.5 MY23.5 SE Defender
Post #1057802 19th Jan 2025 3:46am
DefenderMidlands
If not it will be under
engine ECU. Menu--Service Test--Engine Service reset MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1057805 19th Jan 2025 7:28am
DefenderMidlands
Or to reset service without gap tool
Open driver door. Leave open
Pull bonnet hatch
Press start stop
Press and hold down brake pedal
Wait 2 seconds. Fully press and hold accelerator pedal.
Wait upto 30 seconds until service reset message appears MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1057806 19th Jan 2025 7:29am
