![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2746 ![]() ![]() |
I do my own oil/filter change every 10k miles, so roughly halfway between the official ones. Its next official service is the 105k one so that will be done at a garage to maintain warranty but once that’s finished I’ll do it all myself. |
emariu Member Since: 12 Jun 2023 Location: Calarasi Posts: 12 ![]() ![]() |
Thanks, I'll check it later |
Emtroulis Member Since: 10 Jan 2025 Location: QLD Posts: 1 ![]() ![]() |
Hi All,
Would you please help me set up the cruise control to increase 1 Klm and no 2? Thank you in advance. |
BobP Member Since: 08 Jan 2025 Location: Pittsburgh Posts: 1 ![]() ![]() |
Does anyone know if the Sirius radio option is installed on the US models from the factory and just needs activated in the CCF files or if it would need a different radio set up? I did see it as an option on EUCD-119/EUCD-125
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2021 ![]() ![]() ![]() |
so I'm kind of hooked and wanting to buy one!
but what is there to unlock on a 2023 V8? is pretty much all of it unlocked on these models? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 118 ![]() ![]() |
I see hunters prestige now offer chauffeur mode activation for the 2024 defender. Does anyone know how to activate this using the G4?
northeye Member Since: 18 Sep 2022 Location: Tokyo Posts: 19 ![]() ![]() |
MultiCAN-665 ChaffeurMode
Fitted MultiCAN-853 TS Sec Seat Movement Touch Screen Control of Secondary Seat Movement - Fitted |
Did anyone get anywhere with this? |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 271 ![]() ![]() |
Service/Test -> IPC-Instrument Pack -> Service Interval Reset .... MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 53 ![]() ![]() |
Corner speed. Did anyone get a new menu item?
Country road assist incorporates two features to reduce the requirement of driver interaction with the adaptive cruise control system. The country road assist features are: Corner speed adaptation – the feature identifies and reduces the vehicle speed to a comfortable value if the current cruising speed is too high for an upcoming corner. Speed limit adaption – the feature identifies the upcoming speed limit and updates the adaptive cruise control set speed. The country road assist features can be enabled and disabled via the touchscreen as follows: Touch the settings icon¹. Select Vehicle. Select Driver Assistance. Select Cruise and Limiter. Select Adaptive Cruise Control: Speed Assist. Select Corner Speed Assist to enable corner speed adaptation. Select Speed Limit Prompt to enable speed limit adaptation. |
kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 30 ![]() ![]() |
I have just tried this but IPC Instrument Pack is not listed? L663 110 D300 MY23.5 MY23.5 SE Defender |
If not it will be under
engine ECU. Menu--Service Test--Engine Service reset MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
Or to reset service without gap tool
Open driver door. Leave open Pull bonnet hatch Press start stop Press and hold down brake pedal Wait 2 seconds. Fully press and hold accelerator pedal. Wait upto 30 seconds until service reset message appears MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
