![]() | Home > My Defender > BeaTie |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
Good plan there Procta
Things usually work themselves out in the long run to make life a little bit less stressful
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5369 ![]() ![]() |
well i thought id have look at a few things while its off the road.
looks like the main leak i have is to do with the gearbox. As i thought it could have been the rocker cover gasket After whipping off the engine cover, all is ok there. So a good stray with carb cleaner cleaned up the engine bay. Also i checked why the boom slang Head lamp loom failed, knew it was an earth, so relocated it, and i have the head lights back in action again, on the loom. Also found out that i have a coolant leak, on the blead screw, on the rad hose. Which just dropped to pieces on me. So a new rad hose and a blead screw on order. Then i decided to look at why the rev counter was so hit and miss, then my binnacle dropped to pieces. I was like sod this! and put the car back together, as things were just not working my way. Something is taking the mick out of me at the moment sadly, I have seemed to have hit a point, where everything is just going tits up. So things are not going my way for me or my family, at this moment. I could really hit someone, really i could. ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Beatie is in for her gearbox replacement, what a ride getting it to the garage. I recon another 10 miles and i recon that would have been Time gentlemen please.
By the time i was coming to the end of journey there, the noise when i was in fifth gear was well bad, the odd slushy noise, was starting to get worse. ![]() Also just before i set off, me and my dad changed the top hose, just move the odds in my favour, got an alu bleed screw, to go on, But that will be installed when i get the car back. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Beatie is back in action! After £1900 quid bill, for replacement box and back to the single clutch and flywheel, No Dual mass this time.
They gave me the story that the mass was toast, i was like ok etc, It was pulling ok before it went in man. They did have good job on mine, but then again its a simple process of swopping a gearbox and clutch over, and not a land rover rebuild. Yeah i have had to pay more than i would have, but they were the only ones free that could do it. All is ok for the moment, and laugh is, the rev counter that works when it wants to, is working now. ![]() I am going to see where i am funds wise, and i will start rolling out some stuff, Really want to do those door cards. Also tonight there i blew away a boy racer in a bmw going up hill, He wasn't happy after been smoked by a defender. All you heard was a worr as he went flying past. ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
That is good news Procta and you can't beat " rollin coal "
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
After a bit of a run with the car, i decided to upgrade the bleed screw from the plastic unit to a metal one from brit part. Not sure if this is a good move, so i have kept the original one in the car. Topped the coolant up with the pink stuff as normal. So i am slowly getting back on track.
![]() Click image to enlarge ![]() Click image to enlarge Also i have a working rev counter ![]() ![]() Click image to enlarge Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
All good there Procta
I showed a buddy at work, what the little gear leaver did, and my diff lock light never came on!
So today i decided to check if things were engaging, turned out they were, so checked the light, Only to find it was unplugged. I am suspecting when they had the landys gearbox out, they forgot to plug it back in! ![]() took me longer to find out where the wire was, than it was to do the job. ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Good find and fixed for zero outlay
Got some little goodies on the way, but we will have to wait until they arrive
![]() Its something that i have toyed with the idea of getting since i bought this one and did the clock rings. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Since i fitted the dash clock rings, from croytec i have been toying with the little caps for the stalks, and i decided to bite, and go for it.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Took a bit of tapping with a bit of WD and they were on. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Next up was find out why my bloody lights went off again ![]() ![]() Click image to enlarge Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Good fix
