Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 77 of 112 <123 ... 767778 ... 110111112>
dsstephens
United States
<double> 2020 SE First Edition
2004 Disco2
1986 110 V8
1971 Series IIa 88”
Post #1027686 11th Mar 2024 9:01pm
Philipp1601
Germany
Hi dsstephens,
I have a feeling you tried to connect to the car with the engine running.
I did the same because I wanted to save battery life.
This did not work for me, too.
Please try to use the IID-Tool with the car set to ignition on but without the engine running.
This way it is possible to write data like CCF to the car.
You could write Patrick from GAP Team an email about your problem: team@gap-diagnostic.com Greetings
Philipp
MY24 Defender 110 XS-Edition D250 Stealth Mod
MY07 VW Multivan T5 Sport Edition D5
MY12 Mini R55 Cooper Works
MY00 MB SLK 320 R170 Designo
MY21 KTM 690 SMC-R
Post #1027693 11th Mar 2024 9:22pm
pjeski
United States
I’m going to chime in here and say that I always connect with the engine running. Both the G3 and now the G4 stop the engine when they need to. If you put your foot on the brake, the GAP tool will restart your engine and the transfer will fail. (My experience anyway).
Post #1027697 11th Mar 2024 9:33pm
dsstephens
United States
Philipp1601 wrote:
Hi dsstephens,
I will give it a shot but as a later poster indicates, it controls stop and start, and section 2.7 says it can be running. I'm happy to give it a shot anyway. thanks! 2020 SE First Edition
2004 Disco2
1986 110 V8
1971 Series IIa 88”
Post #1027698 11th Mar 2024 9:35pm
dsstephens
United States
I did pay special attention to keeping my giant feet away from the brake pedal. In any case, I'll try again this evening. 2020 SE First Edition
2004 Disco2
1986 110 V8
1971 Series IIa 88”
Post #1027699 11th Mar 2024 9:37pm
muppetry
United States
dsstephens wrote:
Got the G4 this weekend and activated. Connected and read. noticed 3 things
1) engine is running, but it is flashing red letters at the top indicating <ign> (need to verify exact wording).
2) when connected, it threw a "emergency braking not allowed" error without any intervention
3) tried changing 007 setting as a simple one and the ACC as not so simple; update failed. tried restoring backup, update failed (even though it hadn't successfully written first). now it throws ATPC and HDC not available errors. Will let it sit and go out and try it all again. open to any suggestions.
I also activated a G4, but without any of those issues. It successfully programmed ACC plus a couple of other CCF modifications. The ACC change did briefly result in an "emergency braking not available" message, but that went away after restarting the engine.
Did you update the G4 firmware after activating the unit?
Post #1027701 11th Mar 2024 9:42pm
dsstephens
United States
ah, I updated it to Build 79, then went outside and activated it and started using it. Based on your (muppetry) message, I ran the updater again, and it updated now to Build 80.
Maybe that was it. Cheers! 2020 SE First Edition
2004 Disco2
1986 110 V8
1971 Series IIa 88”
Post #1027707 11th Mar 2024 9:59pm
dsstephens
United States
ding ding ding. AFTER activating was the key here, not before activating. Worked the charm. Cheers. 2020 SE First Edition
2004 Disco2
1986 110 V8
1971 Series IIa 88”
Post #1027719 11th Mar 2024 10:29pm
pjeski
United States
Glad it worked, but when mine arrived, the updater told me I already had the latest and I activated without updating. A few days later an update was available. I should check again.
Post #1027722 11th Mar 2024 10:33pm
tooth_dr
Northern Ireland
My G4 (already sent back my G3 to Canada) is arriving next week but I’ve been hit with a £59 charge by ups. Anyone else get charged?
Post #1028074 14th Mar 2024 10:07pm
coda0
United States
It cost me about $45 to send my G3 back to Quebec.
Post #1028076 14th Mar 2024 10:23pm
Down & Dirty
Yep Crying or Very sad got a £58.00 ups charge, but delivery tomorrow Mr. Green
(I too sent my g3 back a couple weeks back)
But we were made aware any charges we would be liable 24MY HSE X-Dynamic 90 Carpathian Grey
Post #1028077 14th Mar 2024 10:23pm
pjeski
United States
Cost me $17 usps. Delivered to GAP today.
Post #1028079 14th Mar 2024 10:35pm
Dicky1961
Cost me £12 to send the G3 back and £0 for the G4. G4 was delivered Wednesday. Chuffed 👍👍
Post #1028082 14th Mar 2024 10:51pm
tooth_dr
Northern Ireland
Cheers fella 👍🏻👍🏻
I’ve already activated the features using JetPro a few months back but have been afraid to tinker further as I only had the 3 day licence and I didn’t want any error codes.
Post #1028086 15th Mar 2024 12:07am
