![]() | Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Great pics, true Defender habitat.
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Let this be a lesson boy and girls.
Buy right, buy once is the moral. A good while ago now I fitted a Provent 200 to Miffy and for some unknown reason and I cannot fathom what I was thinking, I fitted plastic hose joiners ![]() Well you can guess what inevitably happened, the darned things warped, went square and the hoses vibrated apart. I think I remember the moment as there was a boost stutter. So the fix is obvious, two brass straight hose connectors with serious barbs on them. They'll never vibrate loose again and just in time for the BIG snow of 2024... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Hello. Apologies for the slow response. Bit manic at this end with house packing. You do not say what age vehicle you have, but from what you say it appears you are not getting 12v to the high beam terminals in the connector. First things first, I assume you have checked that the main beam fuses are still good?! If a TD5 you should be checking fuses 15, 16, 17 and 18. You should also check the relay R123 in the fuse box too. After that the obvious culprit is the light switch itself, these are known to be fragile and degrade with time and use. May I suggest you get yourself a simple multimeter to test that you have 12v at both the dipped and main beam headlamp terminals, then work backwards to the switch. The full beam flash is a different circuit so at least you know the headlamps do work, so it must be the switch, relay or fuse. Best I can do from here. Good luck ![]() |
Well, Miffy has been pressed into action this past few weeks as she is helping us move house. Well she couldn't just sit there idle could she
![]() Loaded to the fore tops and honestly you wouldn't really know, she just keeps on trucking on. I think this is one of the best things about the old Defender, it just does the job come rain come shine come stuffed to the roof with service items, spares and the garden shed ![]() But, I couldn't leave her unrewarded now could I... ![]() For a while now I have been thinking about removing the Puma front seats (yes I know I only refurbed them last summer) and refitting the standard TD5 seats with Techno cloth. I know it will be considered a weird decision as XS is better, right?! Do not get me wrong the half fleather Puma seats are very smart looking but I do find that I sit perched on the seats rather than in the seats. The problem is that in winter the fleather is hard and cold, then in the summer it scalds the backs of your thighs ![]() ![]() Click image to enlarge ![]() Click image to enlarge These came out of a truck cab I think as they have the plastic rubbing strips not he rear, well mostly, they need replacing as they have gone missing. The CSW versions didn't have these fitted, but did have rear pockets which I will miss. The seats are also missing one recliner handle which is not a problem. The only bad point is the worn seat base cover, the foam is still good. Not great but I will replace it. The interesting thing is that even sitting on them in the kitchen they are supremely more comfortable than the Puma seats. Each to their own I have no doubt. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Oh and they are heated as well, which is nice. Plus they will match the rear seats which never got "upgraded" to Puma XS spec. I know this will be seen as a strange decision for some who aspire to having an XS spec Defender, but I never claimed to be "normal" ![]() |
I think the suffering/interesting life decisions Land Rover ownership comes with precludes us from normality...
![]() ![]() I think Lord Haggis that should be printed on forum t-shirts ![]() |
"The Choice of The Inertersing Motorist Since 1948"
Honestly it is hard not to be defined by these vehicles, but I do like what they represent very much. It is a strange old life
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
It is a funny old world, i had those in Millie for years until i decided to put the XS seats in Millie but i did put seat covers on all three ( Exmoor trim ones ) they are a great improvement and to me they are more comfy
Great quote ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I know I know it has been a while... But moving house and job half way across the country has been a tad all consuming
![]() Anyway... Good news... After 22 years, 20 MOTs and more miles under her belt than is polite to state for a lady... ![]() Click image to enlarge And... I remembered to advise the MOT tester of the ATB diffs as well ![]() |
All good
Just have to say Clay that it was wonderful to take her for a good spin down the road this morning. I suspect the poor ol Nottinghamshire commuters fear for their lives now Miffy is resident on their roads
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347 ![]() ![]() ![]() |
Superbulous! |
