Home > Technical > TD5 Rev counter install
Page 3 of 4 <1234>
klacinak
Hungary 1999 Defender 130 Td5 HCPU Coniston Green
Thank you Hank! My main goal is to avoid of alternator cabling but if there is no other solution I will go ahead for this, thanks again!
Post #781250 12th Jul 2019 3:59pm
hank
Post #781263 12th Jul 2019 5:15pm
Martin
Site Admin
Also the CAI version: https://www.defender2.net/forum/topic62582.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #781274 12th Jul 2019 7:36pm
klacinak
Thank you Martin! I will have a look at it.
Post #781897 17th Jul 2019 6:25pm
klacinak
Finally, I had some time and got the result. It is working from the ECU (NNN)
https://files.fm/u/h46epws6
I will create and post a summary.
Post #828729 30th Apr 2020 9:53pm
Bingo
Russia 2005 Defender 90 Td5 HT Santorini Black
Good afternoon. Please tell me how you connected the VDO tachometer? Have you connected it to pin 19 of the black ECU connector? When the ignition is turned on (before the engine starts working) is the tachometer needle moving?
I purchased a tachometer from VW Jetta mk1, connected it to pin 19, but the arrow does not move from 0. I want to understand what the problem may be - whether the tachometer is faulty, or something else... Thanks!
 “A word of command has made these silent figures our enemies; a word of command might transform them into our friends. At some table a document is signed by some persons whom none of us knows, and then for years together that very crime on which formerly the world’s condemnation and severest penalty fall, becomes our highest aim.”
— Erich Maria Remarque
Post #951962 8th May 2022 6:27pm
klacinak
Hi Bingo!
You need to make a PCB to convert the signal for the VDO.
I attached the schematics. Any NPN transistor is fine.
I think you will need to enable the RPM output of the ECU but let's see if the PCB is enough or not.
If you have questions, let me know.
Post #952047 9th May 2022 11:17am
Bingo
klacinak wrote:
Hi Bingo!
Hello, Klacinak (Unfortunately, I do not know your name...)!
Thank you for the quick response! Unfortunately, I don't quite understand the circuit - the details marked with circles, as far as I understand, are resistors. Please tell me, what is the nominal value of their resistance? Thanks!
Post #952068 9th May 2022 2:29pm
klacinak
Hi Bingo,
their value is 1 kilo-ohm. 1/4 Watt is enough, does not need bigger.
Laszlo
Post #952070 9th May 2022 2:53pm
Bingo
Thank you very much, Laszlo! Smile “A word of command has made these silent figures our enemies; a word of command might transform them into our friends. At some table a document is signed by some persons whom none of us knows, and then for years together that very crime on which formerly the world’s condemnation and severest penalty fall, becomes our highest aim.”
Post #952091 9th May 2022 6:46pm
hydraulic_landy
Germany 2003 Defender 110 Td5 CSW Bonatti Grey
Hi all
could the signal, coming from ECU Pin 19, switched on/off via Nanocom?
somewhere in the forum I've seen a picture of the nanocom screen there was shown
"Tacho: enable/disable"
but I can not find this picture right now and I didn't find this "switch" on my nanocom
Background:
I fitted a used VDO rev counter with the above mentioned additional electronic, but it didn't work.
I don't know whether the rev counter is broken or the signal is not okay, maybe switched off?
Thanks
Peter
Post #1021732 19th Jan 2024 7:04am
Martin
Site Admin
Have you tried a pullup resistor?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1021735 19th Jan 2024 7:32am
hydraulic_landy
I tried not the pullup solution, I tried instead the solution shown in the video:
Maybe that's wrong for the VDO type
Peter
Post #1021743 19th Jan 2024 9:35am
Martin
Site Admin
What’s the solution in the video?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1021747 19th Jan 2024 9:58am
TexasRover
It looks to be the same solution that I used, which is to just connect it and it works.
He is saying there is a pull up resister build into the tacho, possibly I dunno, but I bought a similar looking 52mm tacho on Amazon for ~euro 35 and it worked. I did have to adjust the little pot meter at the back and pull a new cable as my loom did not have a cable.
Post #1021748 19th Jan 2024 10:06am
Page 3 of 4 <1234>
