Page 1357 of 1392 <123 ... 135613571358 ... 139013911392>
excossack
Fitted a set of MudStuff seat rails, now I have both front seats raised and both have move adjustment. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1015087 14th Nov 2023 4:22pm
excossack
After a drive yesterday, I am not 100% convinced on the extra height the rails give.
I am not sure if its something I need time to get used to or not.
If I am sticking with the extra height then I need to alter the cubby box height as now its too low. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1015158 15th Nov 2023 10:38am
AJC
i had rails, i fit them when i bought it, then removed them a year later and don't feel like i need them now
Post #1015174 15th Nov 2023 1:05pm
excossack
I need to give the rails a bit longer to see if I can get comfortable with them. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1015175 15th Nov 2023 1:10pm
geobloke
Fitted a new alternator to Miffy... 18.6v at 3000rpm = engine into limp mode Shocked Shocked
Post #1015201 15th Nov 2023 5:05pm
excossack
Errr...Thats not quite right. What make did you go for ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1015203 15th Nov 2023 5:15pm
geobloke
Hi John, I went for a Hella in the end as I could not get a Denso in time and Hella is supposed to be a decent 'safe' brand. Apparently made in Germany. What could go wrong eh?!
Tell you what though, the TD5 does not like 18v Shocked Gauges do some weird things. No fault codes though. I will get it sorted tomorrow.
Post #1015212 15th Nov 2023 6:24pm
Screbble
Should go faster though… Rolling with laughter
When I upgraded by cordless drill from a 12v model to an 18v model it was an improvement all round - you just need to give it time…
Post #1015221 15th Nov 2023 7:08pm
geobloke
Ha just been looking back at the video... 19.3v... Shocked Shocked Shocked Shocked Shocked
Heated seat has never been so warm...
Yikes.....
Post #1015222 15th Nov 2023 7:15pm
Cra1gSG
United Kingdom 1999 Defender 90 Td5 HT Rutland Red
Well the work wasn't today, more like over the past week or so!
Here's what's been done ....
"Pickaxe" getting some TLC & modz! 😍
What started out as a treat for her after Mudmaster evolved into some other jobs and modz πŸ˜†
Iv fitted the new following parts ...
β˜† Allisport air intake pipe.
β˜† Water pump
β˜† Allisport exhaust manifold & stud kit.
β˜† Full set of Roose blue silicone hoses.
β˜† Allisport header tank
β˜† Allisport rocker cover & header tank caps.
β˜† New belt tensioner.
β˜† Clean & Intercooler.
β˜† Change & modify airbox to a twin inlet. Also removed the cyclone.
β˜† Fabricate another air inlet intake for n/s wing.
β˜† Fit and run air intake on n/s.
β˜† Weld on brackets then fit S/S Bush wire kit
β˜† Oil & filter / service plus new antifreeze etc.
 β–€β–„β–€β–„β–€β–„ "𝑭𝒍𝒂𝒕 𝒕𝒐 𝒕𝒉𝒆 π’Žπ’‚π’•, π’˜π’Šπ’•π’‰ 𝒕𝒉𝒆 π’‘π’‚π’“π’•π’š 𝒉𝒂𝒕!" β–„β–€β–„β–€β–„β–€ 🀠
Post #1015260 15th Nov 2023 10:10pm
Screbble
Ooh Allisport… Thumbs Up
Nice header tank (nice everything to be fair).
And you’ve got the sight glass Bow down
Post #1015269 15th Nov 2023 10:39pm
Cra1gSG
Thank you Screbble πŸ˜„
All the jobs evolved into "well I may aswell just do it while I'm here" πŸ˜†πŸ» β–€β–„β–€β–„β–€β–„ "𝑭𝒍𝒂𝒕 𝒕𝒐 𝒕𝒉𝒆 π’Žπ’‚π’•, π’˜π’Šπ’•π’‰ 𝒕𝒉𝒆 π’‘π’‚π’“π’•π’š 𝒉𝒂𝒕!" β–„β–€β–„β–€β–„β–€ 🀠
Post #1015270 15th Nov 2023 10:44pm
excossack
I am not surprised the TD5 doesn't like 18v
Hella lot of voltage..... 1999 Defender TD5 110
Regards
John M0VAZ
Post #1015292 16th Nov 2023 10:06am
geobloke
Ha... Rolling with laughter Rolling with laughter Rolling with laughter
Well all is back to where it should be. Picked up the replacement replacement alternator and Miffy is now being supplied with a consistent 14v +/-.
Good for another 200k miles or so Thumbs Up
Post #1015327 16th Nov 2023 3:28pm
excossack
14v FTW! 1999 Defender TD5 110
Regards
John M0VAZ
Post #1015330 16th Nov 2023 3:49pm
