excossack Member Since: 22 Feb 2012 Location: North West Posts: 6019 ![]() ![]() ![]() |
After a drive yesterday, I am not 100% convinced on the extra height the rails give.
I am not sure if its something I need time to get used to or not. If I am sticking with the extra height then I need to alter the cubby box height as now its too low. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
i had rails, i fit them when i bought it, then removed them a year later and don't feel like i need them now
I need to give the rails a bit longer to see if I can get comfortable with them. 1999 Defender TD5 110
Fitted a new alternator to Miffy... 18.6v at 3000rpm = engine into limp mode
Errr...Thats not quite right. What make did you go for ? 1999 Defender TD5 110
Hi John, I went for a Hella in the end as I could not get a Denso in time and Hella is supposed to be a decent 'safe' brand. Apparently made in Germany. What could go wrong eh?!
Tell you what though, the TD5 does not like 18v ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
Should go faster thoughβ¦
![]() When I upgraded by cordless drill from a 12v model to an 18v model it was an improvement all round - you just need to give it time⦠|
Ha just been looking back at the video... 19.3v...
![]() ![]() ![]() ![]() ![]() Heated seat has never been so warm... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Yikes..... |
Cra1gSG Member Since: 01 Nov 2023 Location: South Lanarkshire, Scotland Posts: 28 ![]() ![]() ![]() |
Well the work wasn't today, more like over the past week or so!
Here's what's been done .... "Pickaxe" getting some TLC & modz! π What started out as a treat for her after Mudmaster evolved into some other jobs and modz π Iv fitted the new following parts ... β Allisport air intake pipe. β Water pump β Allisport exhaust manifold & stud kit. β Full set of Roose blue silicone hoses. β Allisport header tank β Allisport rocker cover & header tank caps. β New belt tensioner. β Clean & Intercooler. β Change & modify airbox to a twin inlet. Also removed the cyclone. β Fabricate another air inlet intake for n/s wing. β Fit and run air intake on n/s. β Weld on brackets then fit S/S Bush wire kit β Oil & filter / service plus new antifreeze etc. ![]() Click image to enlarge ββββββ "ππππ ππ πππ πππ, ππππ πππ πππππ πππ!" ββββββ π€ |
Ooh Allisportβ¦
![]() Nice header tank (nice everything to be fair). And youβve got the sight glass ![]() |
Thank you Screbble π
All the jobs evolved into "well I may aswell just do it while I'm here" ππ» ββββββ "ππππ ππ πππ πππ, ππππ πππ πππππ πππ!" ββββββ π€ |
I am not surprised the TD5 doesn't like 18v Hella lot of voltage..... 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Ha... ![]() ![]() ![]() Well all is back to where it should be. Picked up the replacement replacement alternator and Miffy is now being supplied with a consistent 14v +/-. Good for another 200k miles or so ![]() |
14v FTW! 1999 Defender TD5 110
