Home > Puma (Tdci) > Puma Shift R
ScarboroughSeadog
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Keswick Green
Puma Shift R
Apologies for covering old ground- to an extent.
About to order either the Shift R or Slickshift, and favouring the Shift R mainly due to the reported rattle issue with the Slickshift (although the Mk2 Slickshift seems to have addressed this somewhat).
Shift R straightforward drop in fit, single piece shaft, but is a little pricier.
There don't seem to be any very recent threads on either, and particularly interested to hear from those who have had the Type R fitted for a while.
Comments appreciated, thanks.
Post #1011766 19th Oct 2023 11:11am
Naks
I've had a SlickShift since 2017, never rattled Thumbs Up --
Post #1011814 19th Oct 2023 4:25pm
hank
I've had a Shift-R since Jun 2019 - excellent piece of kit > 110 XS Double Cab
Post #1011829 19th Oct 2023 5:22pm
NoLimits
United Kingdom 2013 Defender 110 Puma 2.2 USW Havana
I have had a Shift-R fitted for about 6 months, no problems with it at all
Post #1011830 19th Oct 2023 5:27pm
ChrisDefender
Shift-R fitted now for a few years and as good as the day it went in. Thumbs Up Thumbs Up
Just use lots of grease.
Post #1011845 19th Oct 2023 6:40pm
hornet
Post #1011895 20th Oct 2023 11:38am
Clarkey
United Kingdom 2014 Defender 110 2.5 TD XS DCPU Fuji White
Slick shift fitted couple weeks ago and brilliant so far.
Post #1011899 20th Oct 2023 12:23pm
bobic
Ireland
I fitted the shift R into mine a few months ago. The original gear lever felt very loose and you could be stirring it around in circles without it actually engaging with anything, I think this is why it rattled sometimes. It certainly feels a lot better in the hand and does away with all that stirring and a lot of the rattles. It significantly shortens the throw or movement of the stick between gears which feels a bit weird at first but you get used to it. I personally liked the longer throw of the original. The number one reason I bought it was that it might help with the quality of the gear change, especially between 1st to 2nd but for me it didn’t improve anything there.
Overall I’m very happy with it and would recommend.
Post #1013970 5th Nov 2023 12:46am
ScarboroughSeadog
Just reporting back in- I've had the shift R fitted for a week or so now. I'd say it was an improvement in general, but not as marked as some have reported. A bit stiffer- especially in reverse which is substantially stiffer. A bit more feel through the stick- which does mean your can feel the graunchiness as well. More positive shifts. Very quick and easy to fit, not too expensive, so overall good. Not necessarily a 'must have', though.
Post #1014971 13th Nov 2023 3:57pm
DAZ110
^^ That’s exactly what I thought when I fitted one to my previous 2011 Defender 90.
Post #1014996 13th Nov 2023 7:28pm
Dorothy
Who is selling the Shift R? Struggling to find one. Seems the Slickshift is about £200. Dorothy - 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
Ethel - 2013 Defender Puma Utility XS
Post #1073183 11th Aug 2025 5:20pm
gilarion
had a Slickshift for over five years, trouble-free, easy to fit. The only problem when fitting, if you use a new turret, is adjusting the bias spring, though Slickshift do an excellent video on how to do that. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #1073184 11th Aug 2025 5:47pm
ScarboroughSeadog -
You should find that will improve, at first it seems a bit stiff, but after a few months you’ll find it’ll be just right.
Dorothy - TMD was where I got mine from, I believe or at least my understanding is they designed them.
When I last looked online, like you I couldn’t see any for sale.
If that doesn’t turn up anything, I’d contact TMD.
If that doesn’t work out the Slickshift is good too so I hear. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1073239 12th Aug 2025 8:54pm
ashtrans
Site Sponsor
I dont understand the need for these, if you understand the principle of a lever, you are just swapping reduced throw distance for increased force, they are not new, I had one on my first car, a beetle in 1987 !!
I dont understand how this is perceived as an improvement, if anything you are making the shift more knotchy and stiffer,
We have customers phone us saying the shifts are not great, sometimes a box issue or oil issue but also sometimes as a short throw type product is fitted,
I have no axe to grind, I just struggle to understand it ! Dave
Post #1073376 14th Aug 2025 3:55pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
You raise good points Dave. I fit a short shifter for an entirely crazy reason: so the shifter wouldn't bash into bottles in my drinks holder. It worked, though the shift is much stiffer.
Post #1073419 15th Aug 2025 2:50pm
