Home > Puma (Tdci) > Puma Shift R
ScarboroughSeadog
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Keswick Green
Puma Shift R
Apologies for covering old ground- to an extent.
About to order either the Shift R or Slickshift, and favouring the Shift R mainly due to the reported rattle issue with the Slickshift (although the Mk2 Slickshift seems to have addressed this somewhat).
Shift R straightforward drop in fit, single piece shaft, but is a little pricier.
There don't seem to be any very recent threads on either, and particularly interested to hear from those who have had the Type R fitted for a while.
Comments appreciated, thanks.
Post #1011766 19th Oct 2023 11:11am
Naks
I've had a SlickShift since 2017, never rattled Thumbs Up --
Post #1011814 19th Oct 2023 4:25pm
hank
I've had a Shift-R since Jun 2019 - excellent piece of kit > 110 XS Double Cab
Post #1011829 19th Oct 2023 5:22pm
NoLimits
United Kingdom 2013 Defender 110 Puma 2.2 USW Havana
I have had a Shift-R fitted for about 6 months, no problems with it at all
Post #1011830 19th Oct 2023 5:27pm
ChrisDefender
Shift-R fitted now for a few years and as good as the day it went in. Thumbs Up Thumbs Up
Just use lots of grease.
Post #1011845 19th Oct 2023 6:40pm
hornet
Post #1011895 20th Oct 2023 11:38am
Clarkey
United Kingdom 2014 Defender 110 2.5 TD XS DCPU Fuji White
Slick shift fitted couple weeks ago and brilliant so far.
Post #1011899 20th Oct 2023 12:23pm
bobic
Ireland
I fitted the shift R into mine a few months ago. The original gear lever felt very loose and you could be stirring it around in circles without it actually engaging with anything, I think this is why it rattled sometimes. It certainly feels a lot better in the hand and does away with all that stirring and a lot of the rattles. It significantly shortens the throw or movement of the stick between gears which feels a bit weird at first but you get used to it. I personally liked the longer throw of the original. The number one reason I bought it was that it might help with the quality of the gear change, especially between 1st to 2nd but for me it didn’t improve anything there.
Overall I’m very happy with it and would recommend.
Post #1013970 5th Nov 2023 12:46am
ScarboroughSeadog
Just reporting back in- I've had the shift R fitted for a week or so now. I'd say it was an improvement in general, but not as marked as some have reported. A bit stiffer- especially in reverse which is substantially stiffer. A bit more feel through the stick- which does mean your can feel the graunchiness as well. More positive shifts. Very quick and easy to fit, not too expensive, so overall good. Not necessarily a 'must have', though.
Post #1014971 13th Nov 2023 3:57pm
DAZ110
^^ That’s exactly what I thought when I fitted one to my previous 2011 Defender 90.
Post #1014996 13th Nov 2023 7:28pm
