Home > Td5 > Td5 110 camper set up
Page 6 of 8 <12345678>
Register
Glorious weekend sacrificed to the doors and foot wells.
Now with sound deadening and acoustic lining.
Wondering if I should have done the door cards as well.
Next stop leisure battery, VSR and heated seats. Everything's a hammer.
Post #1010599 9th Oct 2023 11:14am
geobloke
Good job. The door cards you can do with a 10mm stick backed closed cell foam for sound proofing. It is light weight, doesn't soak up moisture and deadens road noise well. I use it above the rear seat boxes on the curved panels and underneath the Trans K9 dog crates as insulation and anti-vibration for the dogs.
This sort of thing https://www.amazon.co.uk/Panana-Insulation...amp;sr=8-4
Cheap and it goes a long way.
Post #1010615 9th Oct 2023 12:19pm
Register
Thanks,
I’ve covered everything I can access on the bodywork with Silent Coat and Dodo mat.
I’ve 1 sqm of Dodo Mat (the close celled foam you refer to) left, so I’ll add that to the front door cards.
Meanwhile, in other news, I managed to fit the leisure battery alongside the starter battery and refitted the front mats.
Just need the VSR and some cables to turn up.
Post #1010713 10th Oct 2023 8:10am
Register
Managed to get the VSR fitted easily enough. Cables a bit long but I now have leisure battery power to the rear.
Now working through mounting the seats and associated wiring.
Most is simple, except the wiring for the runners works forwards connected +tve and -tve and backwards connected -tve and +tve.
Is there a switch that can do that?
Thanks. Everything's a hammer.
Post #1010855 11th Oct 2023 11:34am
Register
Completed the dual battery set up.
Fitted heated RX-8 seats and dash switches and ran a bunch of cables. Apparently not everyone’s taste.
Lots of spaghetti routed to the cubby box -
RH seat adjustment power
RH seat heat pad
RH seat heat switch
LH seat heat pad
LH seat heat switch
Leisure battery +tve and -tve
Starter battery +tve and -tve
USBs +tve and -tve
OBD2 cable
I can charge the batteries from here. Although I can access the batteries under the seat base, the seats are bolted in so I now have an option.
I think I need 3 relays for the seats, then a ‘false floor’ and hopefully never see it again.
Post #1011328 15th Oct 2023 7:28pm
Register
Headlining and lights from leisure battery now fitted.
Almost ready to test the Roamerdrive and sound deadening.
And stop putting off the camper interior. Everything's a hammer.
Post #1011671 18th Oct 2023 2:34pm
geobloke
Oooo look at you with your RX7 seats Thumbs Up Are they heated?
Great job getting it to this stage Thumbs Up
Post #1011675 18th Oct 2023 3:41pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
You've done a nice, tidy job with the lighting & wiring there.
is the leisure battery connected to the cranking battery at all? I'm considering one as I kinda want a fridge in my own car.
Also, are those additional lights on their own switch? 4.0 V8 Defender 90
My Instagram
Post #1011677 18th Oct 2023 3:45pm
Register
Guy - RX-8 seats, electric and heated 😀.
Now with two added switches.
LJ Marsden - I’m certainly no sparks, but I now have everything working.
I managed a relay from the dash switches for the heating to each seat, but couldn’t figure the circuit for motorised seat, so that’s currently permanently live. Probably not a good thing.
Simple false bottom to the cubby box keeps everything out of reach.
Additional roof lights and exterior work light (and other bits yet to fit) will run off the leisure battery via this eBay switch panel, which I’ll work into the interior near the back door.
Run out of excuses, now need to do the interior. Everything's a hammer.
Post #1012129 22nd Oct 2023 5:42pm
Register
No idea if this works, but first draft of interior.
https://app.sketchup.com/share/tc/northAme...source=web Everything's a hammer.
Post #1012537 25th Oct 2023 8:52am
geobloke
Love that you went for the LR heat seat switches. Looks great Thumbs Up I have been sorely tempted of late to dump my ARB style switches that I use for roof lights, cruise control and battery link for a set of TD5-esk versions that Mud Stuff do. Then mount them in that little recess under the radio. Need and tidy... and more room for gauges Mr. Green
Post #1012542 25th Oct 2023 9:32am
TexasRover
You know one day the fun will have to be over and you have to start using this car...
What are you going to do then? Just use it?
Post #1012548 25th Oct 2023 10:13am
geobloke
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Don't be daft TR when you own a Defender he fun never stops...
Thumbs Up
Post #1012555 25th Oct 2023 11:26am
Register
Guy - the switches are of course the 'TD5-esk versions that Mud Stuff do'. They look identical to the genuine LR part and when pressed operate the seats. What's not to like?
I'm a bit of a believer that old's kool, so can't ever see anything fancy happening.
TexasRover - you're almost right.
I did however use it yesterday for the first time since I started on the 'build'.
The Roamerdrive, delivered on the promised miracle and whilst work so far hasn't achieved the refinement of an S-Class Merc, its a hell of an improvement.
Onwards to the fun that never stops. Everything's a hammer.
Post #1012561 25th Oct 2023 11:50am
Register
Not much to celebrate.
Really ought not have listened to the guy who said ‘measure once cut twice’. Big Cry Everything's a hammer.
Post #1013000 28th Oct 2023 5:48pm
