Home > Td5 > Td5 110 camper set up
Page 3 of 8 <12345678>
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Sorry for my poor wording, I agree that putting the sound dampener on the flat floor panels in the footwell is beneficial. I was referring to removing the dash and doing the firewall, as I have seen done in many “restorations”. There is little to no benefit in my estimation in doing that.
Cheers 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1001542 24th Jul 2023 2:54pm
geobloke
Completely agree Thumbs Up
Post #1001548 24th Jul 2023 3:14pm
Register
4RF RDS, Guy,
thanks both for your thoughts. I'll leave the dash in place on that basis but will do the sloping part of the bulkhead.
I'll have a look at the transfer box for a reference, but assume as everything else is original this should be as it left the factory. Fingers crossed.
Good to know the alarm is just the sensor doing its job. I went for the obvious solution which has left me without central locking, but I'm not going anywhere for a bit.
Looking at the Roamerdrive fitting instructions, the gearbox tunnel has to come out, so I may do that also.
Just need to rob a bank.
Pete
Post #1001589 24th Jul 2023 7:59pm
geobloke
If you are taking out the transmission tunnel then it makes sense to butyl mat it whilst it is on the bench
And just for inspiration
Post #1001644 25th Jul 2023 9:18am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Evil Elsie wrote:
Quote:
Be so careful to fight the urge to use your fingers to run along the edges to push down, the tin foil is like a surgeons blade and when you feel it its too late and a lovely deep cut in the finger.
I do wish this was posted 3 weeks ago. My thumb has only just become reusable after doing the above.. 👍👍
Laughing Laughing Laughing ah painful isn't it
Post #1001682 25th Jul 2023 11:48am
shanecl
Register wrote:
Guy - hi, I assume I’m on standard not disco ratios so am definitely tempted by the Roamerdrive
I plan on ‘plastering’ everything with sound deadening and have removed some very substantial 3d formed matting from the footwells/tunnel, which I’ll put back afterwards.
How far up the bulkhead should I go? Is it worth removing the dash?
I haven’t disturbed the electrics, but the alarm now goes off a couple of minutes after I lock the doors. Could this be because I’ve removed the interior and the under seat panels with a clear view to the road?
Is the sensor misreading the volume or ???
Thanks.
Pete
Noooo don't plaster everything, only 30% of the panel has to have the sound deadening on it.
Post #1001683 25th Jul 2023 11:51am
Register
Guy - someone did a rather good job of that trans tunnel.
What’s the object on the right in the photo of the Roamerdrive parts?
Thanks for the advice on the transfer box label. Cleaned up nicely - 1.410 ratio.
Now sorting postage with Robyn at Roamerdrive. Do I need the finned sump? What about the oil temp sensor?
Shanecl - I’ve got 11sqm of butyl to use up somewhere.
Thanks
Pete Everything's a hammer.
Post #1001789 25th Jul 2023 10:07pm
geobloke
From left to right
Gasket
O-rings
Fixings
Gear lever
API GL4 75-90 oil
Gear lever boot
Overdrive
Lever linkage
Extended sump
Instructions
and... R380 turret
The turret is not a necessary item, but Miffy's was worn so was replaced at the same time to make the gear change a little crisper.
As for the complete coverage it was done less for sound proofing and more for heat reduction.
Post #1001807 26th Jul 2023 8:52am
TexasRover
Actually I just fitted the roamerdrive I bought 2 months ago (.. work). These are my findings:
Installation was straight forward. I bought a new timken bearing to avoid having to remove the existing one. Left the original race in place all looked good. Had the roamerdrive installed in under an hour. Then I fitted the extended oil pan after that. Oil refill little messy as always, you need a fair bit of oil. The fill plug that came with the roamerdrive is some weird size and I had no matching spanner so I just fitted the original plug back for now. Obviously filled the roamerdrive with oil as well.
All good till it came to reinstalling that tunnel back. I hate that thing, l have AC which does not help. Problem I had is that the roamerdrive lever bracket is hard up against the tunnel. I have a mint tunnel and a raggedy one. As these are nla I decided to butcher the raggedy one to create space, then filled in the hole with the foam pad. It came out OK but I think that's a bit of a flaw. Or maybe my gearbox is badly offset to the left?
Also as I have a LHD I had to turn the main gear lever one more notch to avoid it clashing with the Roamerdrive lever.
Now for driving: It's glorious! No wining on power or overrun, no noises at all. The difference in engine noise at 90-110 kph is remarkable. On my car anything above 2200rpm is booming loud, with the roamerdrive you are well below that. Today I did about 300km with a camping trailer in tow and it was bliss. Still enough to overtake trucks comfortably and take reasonable inclines. On B road I found myself keeping it in overdrive and shift to 5th when needed.
Certainly I recommend it, but I would like to know how others handled the gearbox tunnel issues
Post #1001880 26th Jul 2023 5:54pm
Register
Guy - thanks for the detailed photo. All makes sense now.
Texas Rover - you've answered my next question as a Timkin bearing is only £20, why not fit a new one?
Much easier to revert to original if ever any problems.
My question was around how the new rollers will interface with 90,000 miles of wear on the race.
Terrific to hear that the installation is not difficult and it delivers on performance. I'm RHD with no AC, full poverty spec, with lots of space hopefully.
Need to confirm shipping to UK (and get that bloody client to pay his bills) and its my next step.
Thanks
Post #1001906 26th Jul 2023 8:42pm
geobloke
No problem at all Thumbs Up
As for the bearing race. If you are changing half you should change the other half as well. Or swap the old 90k bearing over to the new OD.
Post #1001955 27th Jul 2023 8:51am
TexasRover
Although I don't disagree that bearings are best replaced as a whole, as long as the bearing and race are in good condition I don't think it us an issue to not replace the race. First of they are not made as a pair, bearings are mass produced to a very high tolerance and just assembled and packed. Then I considered the risk of damaging the old bearing at removal, or the race for that matter. You would probably have to remove the transfer case to get the race out properly.
I just fitted a new bearing and kept the original race in place. The race and old bearing looked perfectly fine and it runs quietly. Obviously it is up to you how you do it. If ever mine starts to get noisy I and always go in again and replace the lot. With the amount of use the car gets, I don't think I will ever get there.
Post #1001959 27th Jul 2023 9:20am
Register
A quick and not terribly interesting update.
I bought a Roamerdrive from one of the UK 4x4 suppliers who also advertise on Ebay.
They advised the following day however that they would refund my money, as they don't have the product. It is still advertised however on both their sites. Sad
In parallel I bought a new input shaft bearing and larger capacity sump which although gorgeous, now sit somewhat forlorn as I arrange purchase of the important bit direct from Roamerdrive.
Sadly now with the addition of 20% Vat and 4.5% import duty.
Death and Taxes. Big Cry Everything's a hammer.
Post #1002922 3rd Aug 2023 9:07pm
TexasRover
Don't worry about being short changed. I was doing exactly the same a few weeks ago. All UK vendors display outdated prices, no one has any in stock. The only importer is Britpart, everyone gets it from them and they have no stock. I am sure when they have stock again the prices will be much higher.
Sane story in Europe, I tried.
The only way currently to buy is direct from Roamerdrive directly from Canada and they are great people to deal with.
Cost a bum, but you will enjoy the result! Good luck.
Post #1002992 4th Aug 2023 11:49am
Register
Good to know I'm not alone.
Unfortunately whilst waiting I've resorted to retail therapy and am now expecting rear wheel carrier, steering guard, ladder and wing chequer plate.
Could be worse.
Almost forgot I'm supposed to be fitting the sound deadening. Rolling with laughter
Pet Everything's a hammer.
Post #1003060 4th Aug 2023 8:25pm
