![]() | Home > Technical > ATB (torsen) front and rear install |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
This is really interesting too, if i had a locker i too would only be using it for crawling over the obstacle, im not one to give it a bootful. if anything having a locker would enable me to travel over obstacles more slowly as i wouldnt need the momentum i currently have to get to bash over stuff. I would only be on standard tyre size too 265/75 so i do find this pretty reassuring. |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635 ![]() ![]() ![]() |
You're welcome. ![]() I'm just thinking back to why I changed and as I recall it was a combination of things - although I rated the ATB ( and still do) I just fancied trying a full locker, and I asked them to put one in the back whilst they were replacing the front one. It was fine with my gentle driving style and limited/occasional needs. JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17943 ![]() ![]() ![]() |
I just wish that Ashcrofts made a version of the ATB with a full airlocking capability, the engineering shouldn't be too complex.
Then you could have the ATB to get into trouble and the full locker to get out again. I guess the market would be rather limited, but I'd buy at least two. |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408 ![]() ![]() |
I’m pretty sure that years ago I saw that kam did a lockable lsd back in the day, maybe wrong though.
I’d certainly buy a pair if Ashcroft made tabs with selectable locking though, the on road benefits of atb and the off-road benefits of full lockers would be a very nice upgrade |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264 ![]() ![]() |
the KAM one used friction plates splined to the outside of the side gears,
The only way you could have an ATB and locker is an ATB with a sliding collar on a extended half shaft spline like the KAM and Maxidrive locker Dave Last edited by ashtrans on 23rd Jul 2023 4:00pm. Edited 1 time in total |
Thanks Dave, I thought that would be the case. Nothing in the pipeline I presume?
not to do this, I am not a fan of the sliding collar locker design,
it would end up as compromise of both designs. Dave |
I have to say that I remain both impressed and completely satisfied with my front, centre, and rear ATBs, and they've never let me down.
That, is a very good reason to fit either an ATB or a locker ![]() |
Show off.... ![]() ![]() |
Well... Two down and one to go... First proper drive tomorrow. ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
I am also very happy with my front and rear Ashcroft ATBs will be doing the centre as soon as I have a good excuse DEFENDER 90 TDCI XS,
Two weeks on and I am still getting used to the ATBs. The difference is quite remarkable, but there are a few observations worth noting at this early stage. Miffy has covered 6-700 miles covering all grades of main roads and a number of green lanes as well.
Vehicle: Miffy is a 2003 TD5 110 CSW without ABS/TC. She has a moderate engine tweak. She does have a full roll cage and ARBs front and rear. Sitting on 285/75/16 AT tyres. She is not the heaviest, but she's no lightweight. Observations 1) Quick junction pull off: This has been transformed. Previously the old girl would spin one front wheel if you gave the pedal a little poke and especially in the wet or cold. No longer. Mirrors. Signal. Shoot of the line... No wheel spinning. Positive acceleration. So much safer. 2) Lift off oversteer: Yikes, that was a surprise, not sure I have read about this one. This happens as you are turning into a corner and lift off a tad. With an open diff you'd understeer and power on out of the corner. But with the ATB in the front the reverse happens. It is not a problem, obviously you just keep your foot planted and hold on ![]() 3) Firm steering: This has been said before, but the front ATB does add weight to the feel of the steering. It is not horrid by any standard, in fact it has the feeling of positive resistance . 4) Return to centre: Also been said before. I like this additional return to steering centre. It is not scary but as above has a lovely positive feel. 5) Fast road: Well obviously within speed limits and the Defenders capability ![]() 6) Braking: I am not sure how the mechanics of this works, perhaps someone can enlighten me. The old girl appears to be stopping much much better. By that I mean shorter distances, straighter and it is almost impossible to lock up the wheels. It must be the transference of power L and R across the axle. I do wonder if this is going to accelerate brake disc and pad wear in the long run. But it is definitely something I can live with, the braking feels much more positive. 7) Gravel/Cobble tracks: Good lord above what a superb level of grip. Now Miffy has always been excellent on gravel tracks, never had much to complain about. She just bimbled along them every now and again into difflock and out again. But the difference is another level above this. Honestly the old adage of "low, difflock, 3rd - go anywhere" should be re-written for us ATB bods. Super levels of traction. Super confident. But, it extends beyond that because slow cobble descents ![]() So, take what you will from that two week review. I believe the steering is lightening slightly as the front diff is becoming used, it feels more transparent than it did initially. The rear is completely invisible. I cannot wait to see how Miffy does over the winter period, we get some incredibly variable conditions here in darkest Denbighshire and is one of the reasons for the for fitting the ATBs. Do I still wish I had ABS and TC.... Hmmm... Less so I think. I would love to drive a Defender with ATBs and TC out of curiosity. I have in the past toyed around with retrofitting ABS and TC to Miffy. It is not a dreadfully difficult thing to do, involved yes, but not impossible. But, I am a bloke who thoroughly enjoys the simplicity of mechanical components and I seriously doubt I would consider retrofitting ABS/TC anymore. Or at least if I do crave ABS/TC it will be for the challenge rather than the requirement, if that makes sense. Lets see how things go from here ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6028 ![]() ![]() ![]() |
For me with only an ATB front and ATB centre I find when hitting patches of standing water the car feels more controlled/stable.
Steering feels better but then I did have pretty much the whole front axle rebuilt (2x CVs, swivel bearings, wheel bearings, & Front ATB installed) There is a roundabout on the way to work, that with the old diff I could get two or four wheel slide if I applied too much right foot on the exit, now with the new diff, it feels more planted. I am yet to try a rally stage in the forest, 'Rocket in/rockets out' at Ty Croes circuit (https://www.angleseycircuit.co.uk/ left hand set of bends shown on the main screen) or Oulton parks grassed areas but this will come by the end of November. I have no doubt it will be better. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
