Home > Expedition & Overland > Table for the Rear Door |
buckers19 Member Since: 02 Jan 2018 Location: London Posts: 93 |
I’m searching for a fold down table for the rear door and came across the front runner one but it’s made specially for jeeps. However, I’ve seen a few people bodge it to fit on the defender door but cannot seem to work out how because of it’s length, it would seem to be too long to fit between the interior door handle and the end of the door.
So...can anyone report on how they got it to fit or are there any recommendations as to alternatives? Click image to enlarge https://www.frontrunneroutfitters.com/en/u...table.html Instagram.com/mattbuckley19 |
13th May 2020 7:31pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4791 |
https://www.defender2.net/forum/topic51267.html
This may help 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
13th May 2020 8:11pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4014 |
Interested in this. I’d love a table like the Frontrunner one that fits properly and neatly on a Puma. All the ones I’ve seen look a bit Heath Robinson in their attachment. 2007 110 TDCi Station Wagon XS
13th May 2020 8:12pm |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 176 |
Mobile storage systems do one, not cheap though
https://www.mobilestoragesystems.net/colle...r-defender |
13th May 2020 8:13pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 559 |
I’ve got the Front Runner table ready to fit to my rear door once I’ve done the restoration.
My rear door has a flat piece of checker plate on with a piece also over the rear wiper. With the table spaced off the door far enough to clear the wiper box it just fits, if I remember right it does cover the door handle very slightly but not enough to cause any problems operating it. If I get a chance tomorrow I’ll take a photo. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
13th May 2020 8:52pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2166 |
Surely must be easy enough to make a nice wooden one yourself?
Keith |
13th May 2020 10:05pm |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 401 |
I’ve got one on my 110 so it does fit but I have a full chequer plate panel and no rear wiper. I mounted it by using longer wheel carrier bolts and drilling straight through the back. This is the only pic I could find, not great but if you zoom in you can just about see it.
Click image to enlarge |
14th May 2020 9:24am |
As Whirly says, it does physically fit but you’d have to make your own brackets depending on which rear door trim you have fitted.
Few pics from this morning with it set up on some clamps! I’ll need 60mm spacers behind mine so it clears the wiper box. Click image to enlarge Click image to enlarge Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
14th May 2020 9:48am |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
I use a drop down shelf from MobileStorage Systems (although I can't see it on their site now) attached to a chequer plate door trim from Devon 4x4. You can see it in the attached photo. The interior doesn't look like this now, but the shelf has served me well for many years. The one from MSS that, I believe, ak615 was referring to is actually their cooker housing for mounting a gas cooker on the back door - not ideal as a simple table.
Click image to enlarge Sorry, best picture I have to hand at the moment, but you get the idea. The best ones, I think, are from Ex-Tec. Not cheap, mind https://shop.ex-tec.de/de/innenausbau-inte...natur.html Tony |
14th May 2020 10:29am |
Timcat Member Since: 20 Jul 2016 Location: Uganda at the moment Posts: 1018 |
They are nice, had our same time as we had the top done..
14th May 2020 1:54pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1833 |
I got one of these on ebay recently at a lot cheaper than the new price. I think it's meant to give the option of a small table - but it's an either/or thing - you can't have both at the same time. The table folds down first, with the stove still folded up against the door. Then you can bring the stove down if you want, but at that stage it takes up the same space. I'm assuming this is how it's designed to work, but when I got it, the table and stove had been fixed together which just didn't seem to make sense, so some fettling managed to separate them. This stove/table combo needs four bolts attached to the back door cover that it can then slot/hang onto. Reading this thread made me realise I could probably make up something else like the front runner one to attach to those same bolts first and then to unfold to the side, or even rustle up a slide-out board that would attach to the bottom of the stove itself. Interesting. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
14th May 2020 2:15pm |
AlexCW Member Since: 04 Mar 2020 Location: Staffordshire Posts: 67 |
What door card and table is this? Looks very smart Alex 2013 2.2 TDCi Puma Hard Top https://www.defender2.net/forum/topic72473.html |
14th Jun 2020 7:51pm |
Think it’s this one I’ve quoted from the post above... 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
15th Jun 2020 2:30pm |
Perfect, thank you.
Should’ve read it better I suppose! Alex 2013 2.2 TDCi Puma Hard Top https://www.defender2.net/forum/topic72473.html |
15th Jun 2020 2:32pm |
