Home > Td5 > TD5 Non Start
Page 1 of 5 12345>
Td5Cam
TD5 Non Start
Hello,
Sorry for what may seem another non start issue, however after searching thread after thread i cant find any similar symptoms (other than it wont start)
Long story short, my landy stalled in gear and when trying to re-start it there was nothing. Only lights on dash are amber ecu lamp, coil light and fog light, had no other warning lamps on with ignition at position II. Managed to push start it and got it home, but have since not been able to get the problem solved. I have done the following;
Replaced starter motor
Replaced Battery
Replaced ignition switch
Checked all feeds including starter relay and there appears to be a good feed of power everywhere
Checked fly wire on starter and is getting a feed
Hoping someone can guide me on where to look next.
Many thanks
Post #725883 28th Aug 2018 8:05pm
bankz5152
Tried the inertia switch? Instagram @defender_ventures
Empire Tuning - Agent
Post #725891 28th Aug 2018 8:26pm
Td5Cam
I havent no, do i need to just press the switch or check the current through it?
Post #725896 28th Aug 2018 8:38pm
bankz5152
Just push it down. Should be it Instagram @defender_ventures
Post #725902 28th Aug 2018 8:51pm
Td5Cam
Will give it a try tomorrow, thanks
Post #725903 28th Aug 2018 8:58pm
stigomery
United Kingdom 2004 Defender 90 Td5 HT Belize Green
When you say it won’t start, you mean it won’t fire or the engine doesn’t even turn over?
You say you replaced the starter motor, new? The solenoid is operating correctly?
Post #725963 28th Aug 2018 10:28pm
grafty99
Sounds like a bad gearbox or transfer box earth to me. I'd be checking all earths and battery connections Thumbs Up
Definately try the inertia switch too as above Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #725970 28th Aug 2018 10:51pm
Td5Cam
Doesnt turn over, as if there is no power, but there is as there is as have checked the voltage and current from the ignition switch right through to the starter and there is a cirrent going right through.
When i turn key to point II on the switch the dash doesnt bring up any of the normal warning lights e.g. battery, oil etc, i just have the amber coil light and eml and a fog warning light, turn the key further and there is just nothing, i can hear the starter relay click and as said above i know its putting current across the circuit.
Have checked the earth and nothing seems to be lose or corroded and the connections at the battery appear in good order.
Brand new starter and brand new battery.
Post #725980 29th Aug 2018 6:52am
grafty99
I'd definately be checking earths straps.... 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725982 29th Aug 2018 7:02am
Td5Cam
Ok will give them another look over once checked inertia switch.
Post #726000 29th Aug 2018 8:30am
grafty99
When the inertia switch is tripped, generally, you don't get glow plug or MIL. 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #726003 29th Aug 2018 8:39am
rallysteve
Inertia switch does not stop the engine turning over on the starter motor. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #726004 29th Aug 2018 8:40am
Td5Cam
Can rule out inertia switch, just checked that.
Will give the earth straps another check and clean them up.
If this fails are there any other thoughts?
Post #726008 29th Aug 2018 8:53am
dorsetsmith
With ignition at position II is main relay and fuel pump relay operating can you hear the fuel pump
1999 to 2001 relay
https://1drv.ms/w/s!AtZSoWFHDgnGhQzNRkjTwxAH0liJ
Post #726012 29th Aug 2018 9:00am
Td5Cam
No cant hear fuel pump.
Post #726016 29th Aug 2018 9:03am
Page 1 of 5 12345>
