Home > Td5 > TD5 Non Start |
It's worth a look. Try removing and reseating it 2002 90 Td5 Station Wagon
29th Aug 2018 1:28pm |
Td5Cam Member Since: 09 Apr 2016 Location: Somerset Posts: 32 |
Didnt make a difference
29th Aug 2018 3:55pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
I would get a jump lead, connect one end to the battery negative and the other to a point on the engine (e.g. lifting eye or similar).
If this works, then you are looking at an earth strap issue. If not further investigation is required. It would also be worth checking the grey earth header which is screwed onto the bulkhead behind the expansion tank as this is where most of the bulkhead loom earths go to. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
29th Aug 2018 4:23pm |
also check earth in bottom driver seat box under ECU
29th Aug 2018 4:51pm |
If the management light and immob light are working the ECU earth must be okay. If the dash lights are not functioning it is more likely to be engine/bulkhead earth
29th Aug 2018 4:54pm |
Bulkhead earths look ok
Tried grounding to engine and nothing |
29th Aug 2018 5:10pm |
Are you sure the battery is actually charged? 02' 110 TD5 Double Cab Rebuild Thread
29th Aug 2018 5:14pm |
Yes just checked it and has decent voltage
29th Aug 2018 5:19pm |
What voltage is it reading? Measure the voltage when turning the key to start too.
Also, Measure voltage at high current starter connection 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
29th Aug 2018 5:27pm |
^ snap
29th Aug 2018 5:31pm |
Was atleast 12.4
29th Aug 2018 5:32pm |
Starter connection roughly same
29th Aug 2018 5:33pm |
bulkhead ground to chassis bonding sounder ok However id check it driver side
29th Aug 2018 5:48pm |
just tried different ground when checking the starter connection, if i ground from the engine its 2 volts at most, try this more than one point engine and gear box
29th Aug 2018 6:04pm |
