Home > Td5 > TD5 Non Start
Page 3 of 5 <12345>
grafty99
It's worth a look. Try removing and reseating it 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #726057 29th Aug 2018 1:28pm
Td5Cam
Didnt make a difference
Post #726077 29th Aug 2018 3:55pm
rallysteve
I would get a jump lead, connect one end to the battery negative and the other to a point on the engine (e.g. lifting eye or similar).
If this works, then you are looking at an earth strap issue. If not further investigation is required. It would also be worth checking the grey earth header which is screwed onto the bulkhead behind the expansion tank as this is where most of the bulkhead loom earths go to.
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #726080 29th Aug 2018 4:23pm
dorsetsmith
also check earth in bottom driver seat box under ECU
Post #726088 29th Aug 2018 4:51pm
rallysteve
If the management light and immob light are working the ECU earth must be okay. If the dash lights are not functioning it is more likely to be engine/bulkhead earth
Post #726089 29th Aug 2018 4:54pm
Td5Cam
Bulkhead earths look ok
Tried grounding to engine and nothing
Post #726091 29th Aug 2018 5:10pm
rallysteve
Are you sure the battery is actually charged? 02' 110 TD5 Double Cab Rebuild Thread
Post #726092 29th Aug 2018 5:14pm
Td5Cam
Yes just checked it and has decent voltage
Post #726094 29th Aug 2018 5:19pm
rallysteve
What voltage is it reading? Measure the voltage when turning the key to start too.
Also,
Measure voltage at high current starter connection 02' 110 TD5 Double Cab Rebuild Thread
Post #726097 29th Aug 2018 5:27pm
dorsetsmith
^ snap
Post #726099 29th Aug 2018 5:31pm
Td5Cam
Was atleast 12.4
Post #726100 29th Aug 2018 5:32pm
Td5Cam
Starter connection roughly same
Post #726101 29th Aug 2018 5:33pm
Td5Cam
However... just tried different ground when checking the starter connection, if i ground from the engine its 2 volts at most, if i ground from say the bulkhead ground its 12.3
Post #726104 29th Aug 2018 5:38pm
dorsetsmith
bulkhead ground to chassis bonding sounder ok However id check it driver side
Post #726106 29th Aug 2018 5:48pm
dorsetsmith
just tried different ground when checking the starter connection, if i ground from the engine its 2 volts at most, try this more than one point engine and gear box
Post #726114 29th Aug 2018 6:04pm
Page 3 of 5 <12345>
