Home > My Defender > Alan
Page 15 of 19 <123 ... 141516 171819>
Profyaffle
Spoke too soon... I got Alan out for a wash as he was dirty from a trip to collect manure a couple of weeks ago, slow to start but did first time.. washed... went for diesel.. a sizeable queue formed at the pumps while I was paying.. came out.. flat battery !!!! Embarassed luckily I managed to roll out of the way and I have one of those jump starter things so off we went.. bit of a pain getting the seat base off as I'd struggled to fit it back in with the new cover on.. I've had a blast up and down the motorway and volts are back up to 13.4 and charging at 14V so fingers crossed.
heres the covers.. copied Clayton Very Happy I like the G4 ones but they tend to be a bit 'sweaty' after a while and get hot in summer.
 1993 200Tdi Defender 90
Post #661648 3rd Nov 2017 3:39pm
Procta
looking neat there, I need new seats tbh, mine have seen better days,
With it starting to get cold now, its a test to see how well the battery is at kicking over the car. My 306 battery is starting to get a little tired now. So it could be worth changing it over for a new one. That's one thing I will be doing with the two is renewing the batteries for heavy duty units. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #661721 3rd Nov 2017 9:23pm
L110CDL
Alan's seats are looking very nice, good choice of colour Wink did your headrest covers fit ok ? they look as if they did Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #662074 5th Nov 2017 10:11pm
Profyaffle
Thanks Clayton, yes they did with a bit of tugging although the passenger one is jammed down and I couldn't shift it to get the velcro to go together so the material is just tucked in... The seat bases are a pain to get back in with eyelet at the back forcing them forward.. That wouldn't normally be a problem but now I'm having battery (Suspect) issues it is.. Rolling Eyes 1993 200Tdi Defender 90
Post #662127 6th Nov 2017 12:37am
Procta
id be looking to install a new heavy duty battery on alan with a cut off switch system. I am going to do this with the 306 I think. due to how often that car is used now. Plus it saves the battery too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #662212 6th Nov 2017 2:50pm
L110CDL
That's a bit strange that the headrest didn't want to come up, my old seat headrests would not come up as they were not meant to Rolling Eyes i found this out after i had to mend the driver's seat frame Very Happy have you had the headrest up at all Question 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #662748 8th Nov 2017 10:11pm
Profyaffle
I had the headrests off when I stripped the seats to re-upholster with new foams, covers and heated elements.. I wonder if i pushed that one back in too far.. maybe I'm just not strong enough Laughing I had to use a jack on a spanner today to get the gearbox oil drain plug undone.. I need more Weetabix.. Wink 1993 200Tdi Defender 90
Post #662751 8th Nov 2017 10:18pm
L110CDL
mmmmmmmmm might pay one day to have a closer look Wink You need to have 3 shredded wheat, not weetabix Laughing
At least you got the plug undone with a bit of creative thinking, at least you know next time it should come undone easier Wink As the battery is giving you the run about, when mine went i put in a Oddessy 0ne, bit more to pay out but it has a much higher cranking output Wink best money i spent on a battery, it never struggles to turn millie over even on the cold mornings Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #662755 8th Nov 2017 10:32pm
Profyaffle
I did try levering it up with a bar.. I will have another tug at it...
My battery is behaving itself at the moment but then I have been driving Alan all week.. I have bought some leads with an Anderson plug so I can connect easily to my jump start battery thingy without having to remove the seat base etc...
I will look into the Oddesey battery, I was contemplating one from Halfords Rolling Eyes 1993 200Tdi Defender 90
Post #662757 8th Nov 2017 10:37pm
L110CDL
That sound s good to me, just make sure your sitting down when you see the price of the battery Laughing good idea with the leads, this is my set up..........................
The leads go in under the metal cover, i cut out a corner so they could fit nice and not squeezed and i did file the metal smooth so no mishaps there Thumbs Up as i got a winch on the front, i have an isolater fitted and i fitted the cables to that so they have to be " switched " on, the cable sits behind the middle seat and will reach out each side for use Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #662765 8th Nov 2017 10:53pm
Profyaffle
That you Clayton... Thats what I had in mind when I ordered the cables.. I use a 175 to 50 adaptor to connect direct to my jump start power pack..
I had a slot cut out of the seat base for the heated seat wiring so I just widened that a tad and tucked the socket behind the seat, the adaptor is plugged in that with a cap on and tucked up in the corner out of harms way.
Post #662840 9th Nov 2017 2:54pm
L110CDL
Nice one Profyaffle Thumbs Up makes it allot easier if someone asks you if you have got some jump leads as there battery is flat Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #662918 9th Nov 2017 10:02pm
Procta
an idea that I could to mine and to my dads! Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #663467 11th Nov 2017 4:21pm
CarMan
I like the seat covers Thumbs Up but what make are they please Question Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top
Post #663479 11th Nov 2017 5:39pm
Profyaffle
Hi Carman,
The seat covers are from Exmoor trim.. a bit pricey but fit very well and are canvas as apposed to the usual nylon/waterproof material. I've just done a couple of 2 hour trips with them and they are great at stopping that 'sweaty back' that vinyl seats tend to give you. Thumbs Up 1993 200Tdi Defender 90
Post #663667 12th Nov 2017 12:14pm
