Home > Wheels & Tyres > Heavy Duty Steel Wheels (Wolf) |
Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258 |
No, no stamps on mine.
I got them at a killer deal, black primed. Got them painted with high end heat resistant paint and still were cheaper than originals by a very wide margin. Was a little afraid that I got flimsy copies but calmed down once compared with an original. Even weight the same. They were easy to balance and are keeping pressure nicely |
1st Oct 2016 8:33am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2552 |
Genuine ones are stamped with the part number, tubed/tubeless, offset, size/width, and Dunlop logo.
1st Oct 2016 7:59pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Hello DorsetSmith, great post.
My Defender uses modulars at present with cheap spacers, bolts too short for my garage's liking. Would authentic Wolves take 255 85 tyres and give a better turning circle without spacers? Also if they are heavier than modulars, I assume they would absorb more bumps and shocks? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
15th Oct 2016 12:30pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1777 |
I now have a spare set of genuine Wolfs to repaint cream/white to match the Puma roof. 4x wheels are in really good shape but silver so I'm assuming a paint shop can simply spray them, but the spare is in more of a mess so would it need bead blasting or similar first? Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
26th Oct 2016 1:51pm |
Wolfs take 255/85s no issue. Turning circle depends on the offset of your current wheels, and if you don't know what the offset is then you can measure it. Once you know the offset of what you've got, add in the spacers and compare that to the offset of the Wolf. Wheels being heavier increase the unsprung weight which should make the ride, handling and acceleration slightly worse. Give it's a fairly heavy tyre I have no idea how much you'd actually notice and the unsprung weight on a Defender is pretty massive anyway. |
27th Oct 2016 7:46am |
Sorry to bump this thread, but it seems like the most relevant place to put this information and I couldn't find it anywhere else.
I've just got my Wolf wheels back from being shotblasted and primed and decided to weight them, and to compare that to the weight of my standard steel wheels. ANR4583, genuine Wolf with no tyre, 15.2kg Standard steel with new 7.50R16 Michelin Latitude, 28kg Weight of tyre (I have a good condition one not mounted) 17kg Calculated weight of standard wheel, 11kg So the Wolf is 4kg per corner heavier. I'd love to know what the Boost alloy weighs, according to one source I've found it's 12.2kg, according to another it's 11-11.5kg. |
26th Oct 2017 5:54pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
You only have to look at the gauge (thickness) of steel used in the wolfs to know they are a heavy wheel! That brings advantages and disadvantages 2014 Keswick Utility 2.2
26th Oct 2017 7:51pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10360 |
I'll have a full set for sale soon, with tyres with less than 1800 miles on them...only ever been wet once.
Click image to enlarge |
26th Oct 2017 9:11pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
What offset are Wolf wheels? Can you get with different offsets? James
26th Oct 2017 9:40pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16883 |
+20.6mm
No. |
26th Oct 2017 10:21pm |
Thank you 😊 James
27th Oct 2017 6:08am |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 716 |
Raptor 4x4 do 'Wolf' style wheels but with an ET0 offset, so will stick out 20mm wider than genuine ones.
http://www.raptor4x4.co.uk/raptor-4x4-wolf...-et-0.html However they are still only 6.5J so wouldn't take anything more than a 255 width tyre. Still, 255/85R16 on those could be a real nice setup and no need for spacers Instagram: l90andy 2006 Land Rover 90 TD5 CSW Silver Edition My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
27th Oct 2017 10:36am |
