Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 47 of 81 <123 ... 464748 ... 798081>
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Here's some pics of it fitted;
Front
Back
Here's the wiring diagram I used
For the switches on the front of cubby pin outs are:
1:earth
2:fused live
3:pin 5 on the rear switch
4:pin 2 on the rear switch
5:fused live
6:illumination
For the switches at the rear of the cubby, so for the second row seats, pins are:
1:isolation switch
2:pin 4 on the front switch
3:window motor (up)
4:window motor (down)
5:pin 3 on the front switch
6:illumination
Make sure you have the correct switches for the front and rear positions, the switches at the front of the cubby are all black and are basically the same as defender window switches, the rear switches however are different and have a grey base to them, they're different inside to as I found out the hard way when the front switches would work perfectly but every time I used the rear switches (i had black based switches the same as the front to start with) they kept blowing the fuse, once I plugged the grey based switches in it worked fine.
Hope this helps
Post #649168 9th Sep 2017 6:37pm
BuckBlu110
I haven't wired the isolation switch yet as I haven't found a connector for it yet so have just earthed them as the isolation switch only switches the earth.
The only issue with the sunroof panel I've found is that you have to be careful cutting the hole in the back of the cubby as there is very little room for error on the one edge of the panel, as the clips are right on its outer edge meaning that if you cut too much of the outer vinyl or leather, it'll leave a gap between the panel and whatever's covering your cubby. Thankfully trim glue saved the day on that one Rolling Eyes
Hopefully if all that makes sense, you'll see what I mean when you get yours Thumbs Up
Post #649173 9th Sep 2017 6:50pm
bankz5152
Smart! Very smart! I was thinking of putting smaller switches (from a BM) on the door card and a button on the dash that just raises the rear windows to the top
Post #649174 9th Sep 2017 7:00pm
mk1collector
That's brilliant, thanks buckblu Thumbs Up I'll go through all that later. Ray
My build thread
Post #649177 9th Sep 2017 7:13pm
mk1collector
Bloody photobucket Evil or Very Mad I've just spent ages replacing most of the early photos on this thread so it makes some sense. Only one or two missing now but what a pain they should be strung up! Ray
My build thread
Post #649611 11th Sep 2017 5:29pm
mk1collector
So the rear electric windows are all in and working but I wasn't happy with the provided mount for the switches so decided to to put them in the doors. Managed to get the surrounds for the switches in this evening
A bit neater than the switches hanging out of the door cards Rolling with laughter
So as mentioned above I just need to wire the rear switches up so I have a set in the front so I can use them while driving Ray
My build thread
Post #649641 11th Sep 2017 8:06pm
BuckBlu110
Looks a top job Thumbs Up
Post #649680 11th Sep 2017 9:24pm
mk1collector
Thankyou Thumbs Up it's another job that's temporary though. I'm just trying to get everything I want together and working so when I sort the new doors out it can put it all back together easier Mr. Green Ray
My build thread
Post #649706 11th Sep 2017 10:21pm
Tiger
Nearly a month and no updates? (sorry make that 2!!)
Post #663059 10th Nov 2017 12:08pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I like that, wish I could trust myself with wiring anything, my 90 would like spontaneously combust if I did it Thumbs Up 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #663062 10th Nov 2017 12:11pm
mk1collector
Yeah I've been a bit busy with other things so not had a chance to do anything to it Big Cry Ray
My build thread
Post #663199 10th Nov 2017 7:39pm
mk1collector
The wiring kit came with the leccy Windows so all I had to do was extend a few of them to reach the doors, it not that hard I'm sure you could do it Thumbs Up Ray
My build thread
Post #663201 10th Nov 2017 7:41pm
mk1collector
Update just for Tiger Rolling with laughter
Finally started fitting the wiring for the heated screen and mirrors today
Doesn't look much but with tidying up a few previously run wires under the dash and adding wires for the mirrors it took me a good few hours Big Cry
All the heated screen wiring is in and the dash back together but I'll have to connect the mirrors up tomorrow as I've run out of light and while the door trims are off I'll fix the central locking broken wire for the drivers door. Are defenders ever finished? Ray
My build thread
Post #664545 15th Nov 2017 5:04pm
Answering your question Ray: no. Laughing
Post #664566 15th Nov 2017 6:31pm
mk1collector
Rolling with laughter it's like painting the forth bridge Rolling Eyes Ray
My build thread
Post #664578 15th Nov 2017 7:06pm
