Home > Maintenance & Modifications > washer jet upgrade... any thoughts... |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 185 |
Has anyone fitted this type of wash wipe upgrade at all?
Any issues? http://www.ebay.co.uk/itm/201763337327?_tr...EBIDX%3AIT Cheers John 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
22nd Jan 2017 9:06pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
I think the only issue is see is neatly running the pipes and much more exposed pipes and so more prone to freezing. Definitely good for washing the screen though. My dad's iveco van has them and they are brilliant 2002 90 Td5 Station Wagon
22nd Jan 2017 9:11pm |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
I'd prefer to go with there other kit as I have aero blades. https://www.ebay.co.uk/itm/201661218144
22nd Jan 2017 11:11pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
when I get chance I'm going to do either this or put two extra std jets using the pump and switch from the rear wiper to activate them.
This way I have the normal jets for everyday driving and the ability to flood the screen in real bad weather or offroading before the wipers even move 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
22nd Jan 2017 11:27pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 711 |
I've done this and can't praise it enough, one of the best driving aids, especially at this time of year when the roads are wet and grimy. Also seems to use less washer fluid.o
22nd Jan 2017 11:58pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
BuckBlu110 do you have any photos of the mod in situ please? - how have you dealt with the existing central washer jet & how have you routed the pipes to each wiper arm from a central exit on the bulkhead? Cheers.
23rd Jan 2017 8:54am |
One of the easiest and neatest upgrades is to replace the single washer jet with two:
Click image to enlarge More details here: http://www.defender2.net/forum/post232942.html#232942 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
23rd Jan 2017 9:50am |
VVS210, I'll take some photos of both my csw and double cab, it'll help explain. I've done them slightly different but the effect is the same.
23rd Jan 2017 9:55am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16947 |
One of the issues with the standard set up, or indeed the two jet modification as shown above, which bugs me is that the nozzle is so close to the plane of the screen that the jet of fluid hits the wiper, and it is difficult to get fliud to the upper side of the wiper blade. A loooooooong squirt is needed to clear the screen throroughly, using a lot of fluid from the woefully inadequate reservoir. I cannot see that fitting second nozzle assembly does anything to improve this.
It is my intention to upgrade to the arm-mounted quad-nozzle arrangement when I get time. |
23rd Jan 2017 10:24am |
Thanks for the photos of the twin jet set up, looks nicely symmetrical. Look forward to seeing photos of the two set ups BB110 has. Cheers.
23rd Jan 2017 11:01am |
The nozzles on the defender are really quite pathetic, certainly an upgrade from the series version but not by much.
Many many years ago now I put together this system based around the Peugeot wiper blade mounted washer jets. Loved this mod as the water was directed to exactly the right place on the screen. http://www.reedx.net/landrover/mods/wipers/ I expect the washers are hard to come by these days. Plus the piping was as tidy as I could get it to be. Like the idea of the wiper arm mounted system, but still the issue with the supply pipe being routed through the front of the bulkhead. Which is why nowadays I have gone for the twin Defender nozzles and they work well, but as stated it can be a pain to get the water to the top of the screen. Added to this the OEM nozzle I bought for the second half of the screen seems to have a mind of its own when it comes to water jet directionality and sometimes produces the perfect jet and more often thean not creates an ineffectual fan that doesn't reach the screen. I have often played around with the idea of modifying a set of Disco 3/4 heated washer nozzles. I have seen them mounted on the the defender bonnet somewhere, but that seems like a stretch in distance and upward angle to get them to work well with a defender. Actually bought a set to play around with. Perhaps I should revisit the idea... |
23rd Jan 2017 11:06am |
In practice, that wasn't the case. The twin streams from each jet found their way around the wipers and because the water was delivered more closely to where it was needed, less was required. I've just bought the bits to carry out the same mod to my current 90, if it ever warms up enough Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
23rd Jan 2017 11:09am |
many thanks for the responses, information and links which have proven to be very useful indeed folks....
waiting to see BuckBlu110's pictures... Thanks again John 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
23rd Jan 2017 10:08pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
Sorry best pic I have of my setup
Click image to enlarge |
23rd Jan 2017 10:34pm |
