Home > Td5 > Alarm interior movement sensor !
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
How do I set the alarm without the interior movement sensor (dog sets it off) The manual says set the alarm with the drivers door open then shut the door. If I do that a get two beeps for a "can't set alarm" ? 2004 110 CSW (Called Yoda)
Post #548750 14th Jul 2016 4:16pm
dorsetsmith
Post #548767 14th Jul 2016 4:55pm
Do you have remote central locking? If so, simpy lock the door with the key, not the remote.
Post #548768 14th Jul 2016 5:03pm
K9F
Simplest solution is to stick some insulation tape over the perimetric sensor.
http://www.defender2.net/forum/topic38997....perimetric
http://www.defender2.net/forum/topic7681.h...perimetric
http://www.defender2.net/forum/topic8354.h...perimetric If you go through life with your head in the sand....all people will see is an ar5e!!
Post #548831 14th Jul 2016 8:48pm
rallysteve
Or if yoy never want to use it. Unclip it from the headlining and unplug it. You can put it back afterwards.
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #548833 14th Jul 2016 8:54pm
Simali
So I need a key
I dont have a key to to fit the drivers door so looks like I need to get one. Will try tape for nk
Simon 2004 110 CSW (Called Yoda)
Post #548912 15th Jul 2016 7:27am
dorsetsmith
ok re your other post door lock
Post #548923 15th Jul 2016 8:41am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Simali, it will honk twice but still set the alarm afterwards. Once you close the drivers door the volumetric sensor will now be deactivated amd the alarm will sound only if a door or bonnet is opened. It does work. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #549078 16th Jul 2016 12:45am
