Home > Maintenance & Modifications > Battery dead but very warm- what do i do?
Page 6 of 6 <123456
shaggydog
Awesome news Thumbs Up
What about the old battery though? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #381090 22nd Dec 2014 7:43pm
Cupboard
shaggydog wrote:
Quote:
The only other thing I can think of is going back to the alternator, you could try testing the resistance of the coils and the wiring, if the diode fails then it wil draw current back from the battery with the engine off. I have come across this before but never as an intermittent fault. Just a thought, fingers crossed.
I'm not sure I have coils as its a diesel Confused But could stand corrected! How would I test that?
coils in the alternator Thumbs Up
A magnet (whether permanent or an electromagnet) spins inside a load of coils of wire. The coils are very tight and have thin insulation on them so can develop faults. The spinning magnet creates an oscillating ~ positive/negative (AC) wave centred on zero which isn't much good for charging a battery, so a collection of diodes is used in a rectifier circuit to make the "negatives" positive.
A diode is like an electrical check valve, only allowing current in one direction. With just one diode you get just the positive humps (so half power), with 4 you can get the negative humps as well. Typically alternators have more than one set of windings so that as the power from one set is decaying, another is coming up to its peak. That way you don't get so much ripple.
Edit to add: in a car, the magnet is usually an electromagnet. That requires current to flow through it in order to produce a magnetic field that then induces a current in the stator (the non-spinny-bit).
Post #381092 22nd Dec 2014 7:44pm
K9F
Read my post about possible battery regeneration 3 pages ago.....Or simply bin it. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #381093 22nd Dec 2014 7:46pm
shaggydog
Quote:
What i ment was sometimes if the alternator is faulty in a certain way then the dash battery light can glow faintly even when engine not running , ign off and you can only see it at night in the dark its that faint
Just gone out in the dark and had a look and everything is dark with not the faintest glimmer from anything on the dashboard.
Interesting didn't realise that Thumbs Up
K9F will have a read and make a decision Thumbs Up
Thanks again chaps! Bow down Bow down Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381098 22nd Dec 2014 7:54pm
munch90
To be honest the thing of flushing batterys out is really from years ago when the individual cells were connected by lead links on top and cells could be removed from the outer casing as they were sealed in with pitch
not really worth the hassle now days as there in glued plastic casings as it would be near impossible to clear out sediment from the bottom
Give it a good charge and keep it topped up if its still got abit of life in it as a jump battery just in case , use it for a 12v lead light when working outside, in workshop for testing bulbs etc
but if it gos flat bin it , not worth mucking about with
you can get a tube of tablets called bat-aid that are ment to give a battery new lease of life , i have used them , do they work not a bl@@dly clue !
But it was worth a try on a bank of fork lift batterys that it wasnt worth buying a new pack for , and yes its still going so maybe ????
Post #381105 22nd Dec 2014 8:17pm
shaggydog
I will leave it on charge tonight so its had a full 24 hours to recharge, if it doesn't hold its power I'll drop it off at my local recycler.
I don't want to risk gassing myself or the dog or being splashed with acid - I have a good working replacement so if it doesn't hold charge its dead. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381107 22nd Dec 2014 8:38pm
yostumpy
Ah but did you feel the new battery to see if it was warm? Wink
Post #381160 22nd Dec 2014 10:33pm
jst
What's the voltage across battery engine running Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #381221 23rd Dec 2014 8:20am
shaggydog
Just checked the battery and was same temp as rest of vehicle so all is well there.
Voltages are as follows:
12.64 - engine off, everything else off.
13.64 - engine on tick over , everything else off
13.80 - engine on revved then on tick over
13.45 - engine on tick over high beams on
13.50 - engine on tick over low beams on
13.14 - engine off everything off, voltage slowly dropping back to 12.64
Did debate testing the amps but I'm not sure my multimeter would take that kind of power. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381305 23rd Dec 2014 3:02pm
dorsetsmith
That looks good to my and your alternator 45 to 50 amps output to much amp of your multimeter 10 amps max
Post #381315 23rd Dec 2014 3:37pm
Cupboard
to measure that sort of current you'd be looking at a clamp meter:
http://cpc.farnell.com/tenma/72-9480/multi...dp/IN06560
Post #381339 23rd Dec 2014 4:56pm
munch90
all looks about right Thumbs Up
don't test amps with your meter
Post #381367 23rd Dec 2014 6:56pm
shaggydog
Thanks chaps for all your help Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381375 23rd Dec 2014 7:58pm
jst
alt is all good then it seems. Cheers
James
110 XS Utility
90 Puma Hardtop
Post #384253 2nd Jan 2015 8:03pm
shaggydog
Seems to be Thumbs Up
Touch wood new battery seems to have cured it.
Thing I notice most is the lights on the dash seem to glow brighter having changed it.
Still, for now, mischief managed thanks again for all your help Smile Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #384282 2nd Jan 2015 9:02pm
Page 6 of 6 <123456
