Home > Maintenance & Modifications > Battery dead but very warm- what do i do? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
AHA!! So, if I disconnect the negative with everything I can turn off turned off, and I get a spark does that say there is something making a circuit so something is wrong? Would a tracker still plugged in cause such a spark? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
22nd Dec 2014 3:29pm |
clock , alarm , tracker will all draw a bit
really you need to get down to maplins and buy a meter |
22nd Dec 2014 3:35pm |
Multimeter purchased
http://www.screwfix.com/p/lap-mas830b-digi...600v/75337 not bad I thought. So. How do I use it and what am I checking? Again massive massive thank you's to everyone who has helped so far Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
22nd Dec 2014 4:00pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
Good job on the Multi-Meter Shaggy...
It would have been my choice if they did it in Green... Just waiting for mine to check out the quality and functionality, if it turns out to be good value, and as well built as some of the reviews suggest, I may even consider a slightly more expensive model, in Green of course... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
22nd Dec 2014 4:13pm |
Thank You Venomator
Like you it was a done deal but because it was blue Anyway had a quick go and hopefully I have found some meaningful things. Old battery after being on charge since 11:30 is showing 12.57 with the number dropping off my a tenth of a milivolt every 5 seconds (is that normal?) with the charged disconnected When I plugged it into the charger again this went to 12.78 and stayed steady. Outside in the defender new battery with everything off I can turn off (only things drawing are tracker and clock and radio) was measuring 12.64 V What does this mean and have I tested the right things? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
22nd Dec 2014 4:33pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
You'd be better connecting the multimeter, set on DC amps between the negative post of the battery and the earth lead. This will indicate what the AMP draw is from the battery. If you've just got the clock and the like running then your looking for 0.5 amp max I'd say, that's around a 6watt consumption about the same as a sidelight. I started with nothing and still have most of it left!
22nd Dec 2014 5:00pm |
Will go and give it a go Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
22nd Dec 2014 5:06pm |
don't try and hurry it , leave it on a low charge for a long time , trying to hurry it along you will get a voltage but no guts to it |
22nd Dec 2014 5:16pm |
Did it but not sure I did it right because nothing much really happened
I have never used one of these before so this is what I did. Unplugged negative lead. Set dial to 2m on A with straight line above and 3 dots below Put red lead to battery - and black lead to the loose cable. nothing happened. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
22nd Dec 2014 5:18pm |
always start with highest amp setting just in case
cant get a big enough pic to see dial and advise middle hole for black lead , red lead 10adc above lap word Last edited by munch90 on 22nd Dec 2014 5:29pm. Edited 1 time in total |
22nd Dec 2014 5:25pm |
10A seems to be the highest setting on your dial? As Munch says, start there and see what you get, although I would go straight to the Earth connector, rather than try and use the loose lead... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
22nd Dec 2014 5:28pm |
Pic of my Multimeter.
I had it set to 2m at 3 o'clock Click image to enlarge Was my positioning of the wires correct (red on battery black on cable) ? Again thank you all for your input hopefully others are reading and learning along too Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
22nd Dec 2014 5:31pm |
10a dial setting at about 5 o'clock on meter dial DONT forget you need to disconnect the battery earth lead , then use the meter leads to complete the circuit again Last edited by munch90 on 22nd Dec 2014 5:35pm. Edited 1 time in total |
22nd Dec 2014 5:33pm |
And you'll probably need to plug the Black lead into the left hand socket...
EDIT - and yes, you were using the cables the conventional way round... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
22nd Dec 2014 5:34pm |
