Home > Technical > Bonding rear door glass. |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Do you mean the pre 2002 rear door where the glass is held in with aluminium angle sections ? If you do then what I used was dum dum but I'm not sure if it's still available, it was ideal as it's easy to use,not messy and you can take the glass out if you don't get it spot on first go. 2005 Td5 90 XS
Steve |
30th Nov 2014 9:05pm |
Andyred90 Member Since: 30 Mar 2013 Location: Wantage Posts: 482 |
It is a pre 2002 door and it does have the aluminium trim on the inside.
Heard that Tiger seal is the stuff to use! Andy |
30th Nov 2014 9:45pm |
Well it won't fall out if you use tiger seal, but it could make replacing the glass at a later date challenging !
The alloy strips will secure the glass in place you just need some thing to seal it. 2005 Td5 90 XS Steve |
30th Nov 2014 10:00pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1762 |
What's about the Kent products that were posted about a wee while ago?
http://www.kenteurope.com/uk/shop/viewfami...;type=Auto 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 250D XS |
30th Nov 2014 10:16pm |
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 |
How about just plain old slicone black sealant about £2.00 a tube
4th Dec 2014 3:32pm |
Super7 Member Since: 05 Feb 2014 Location: South Bucks. Posts: 131 |
I'm also converting a truck cab into a hard top, almost got all the parts I need
I bought a new door from SP Landrovers and asked for the glass to be sent unfitted. It came with some flat rubber strip to be fitted between the glass and the door. I can't see it on their website but they're very helpful and I'm sure they'd sell you some Dave |
4th Dec 2014 4:36pm |
