Home > Technical > Bonding rear door glass.
Andyred90
During the conversion of a pick up into a Hard top I have to fit a new rear door.
As I want to reuse the glass from an old door what is the best way to remove the glass and also what adhesive is used to rebond it into the new door?
Thanks folks
Andy
Post #375321 30th Nov 2014 8:37pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Do you mean the pre 2002 rear door where the glass is held in with aluminium angle sections ? If you do then what I used was dum dum but I'm not sure if it's still available, it was ideal as it's easy to use,not messy and you can take the glass out if you don't get it spot on first go. 2005 Td5 90 XS
Steve
Post #375333 30th Nov 2014 9:05pm
Andyred90
It is a pre 2002 door and it does have the aluminium trim on the inside.
Heard that Tiger seal is the stuff to use!
Andy
Post #375351 30th Nov 2014 9:45pm
Lou Sparts
Well it won't fall out if you use tiger seal, but it could make replacing the glass at a later date challenging !
The alloy strips will secure the glass in place you just need some thing to seal it. 2005 Td5 90 XS
Steve
Post #375362 30th Nov 2014 10:00pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
What's about the Kent products that were posted about a wee while ago?
http://www.kenteurope.com/uk/shop/viewfami...;type=Auto 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 250D XS
Post #375373 30th Nov 2014 10:16pm
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
How about just plain old slicone black sealant about £2.00 a tube
Post #376340 4th Dec 2014 3:32pm
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
I'm also converting a truck cab into a hard top, almost got all the parts I need Thumbs Up
I bought a new door from SP Landrovers and asked for the glass to be sent unfitted. It came with some flat rubber strip to be fitted between the glass and the door. I can't see it on their website but they're very helpful and I'm sure they'd sell you some Very Happy
Dave
Post #376358 4th Dec 2014 4:36pm
