Home > Puma (Tdci) > Sticky Ignition unit |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5428 |
Mine is similar. Some times key stuck in, can't get it out, can't turn it
Andy |
11th Jul 2014 8:09am |
Is it linked to this?
http://www.defender2.net/forum/topic29850.html |
11th Jul 2014 8:13am |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Hi Andy
No i don't think it is, it doesn't stick as such, it just won't turn to position 1, and when switching the engine off, it won't go to position 0/off very easily either, it 'feels' like the barrel and latches are not working correctly, or the steering lock is interfering with it. JD 2008 TDCi 2.4 XS CSW |
11th Jul 2014 8:17am |
I have had similar issues on mine and just put it down to poor tolerances in the sum of the parts. It happens less now but is a pain when it does happen as it can take a minute or more of wiggling to resolve.
11th Jul 2014 9:20am |
What you two are describing is like mine, but that thread got me worried about if it gets worse to a point when it sticks in the on position. Got a xeng barrel lock to fit but have been to worried for months.
11th Jul 2014 9:37am |
Is it a big job to change the barrel ?
11th Jul 2014 9:51am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16940 |
It's not easy to change the barrel since the lock assembly is secured to the column by shear-bolts. It is time-consuming.
New lock assemblies are not especially expensive however (though I am not sure about current main dealer prices). I bought a set consisting of a new stearing column lock assembly (c/w 'ignition'/starter switch) and a driver's door lock assembly when I found that my driver's door lock had siezed, but in the end managed to un-sieze the lock. It was a genuine part from Ebay and was under £50. I bought the pair so that I still only needed one key. |
11th Jul 2014 10:34am |
I had a feeling it wouldn't be easy
11th Jul 2014 10:55am |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 695 |
I'm going to have to do mine. It's starting to worry me that it might just stop working altogether.
Someone said that it's a top part of the dash out job .. Is that right? 2008 Defender 110 XS SW - M57N2 / 6HP28X |
12th Jul 2014 12:14am |
Might have to get mine into dealer. I hate the ideas of others fiddling.
Andy |
12th Jul 2014 6:44am |
Wish I hadn't said that .. It's stopped working altogether and somehow I have to get to work on Monday. 2008 Defender 110 XS SW - M57N2 / 6HP28X
12th Jul 2014 6:41pm |
I tried some WD40 and it made it even worse. I was all prepared to take it out and had the dash apart and then took the advice of mk1collector (thanks) and got some graphite powder .. It's usable again,
Got the graphite lock lubricant from Maplin .. I would give it a go before going to the hassle of changing it. 2008 Defender 110 XS SW - M57N2 / 6HP28X |
13th Jul 2014 5:05pm |
Hmmm i wonder if toolstation might sell it, is it a spray ?
13th Jul 2014 5:29pm |
Yeah .. Tiny can .. http://www.maplin.co.uk/p/ambersil-graphite-lock-lubricant-n68jb 2008 Defender 110 XS SW - M57N2 / 6HP28X
13th Jul 2014 5:39pm |
