Home > Maintenance & Modifications > Air box mod and decat |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Ahhh that will be it, hehe its been a long day and my brain is not working as fast as it should lol
28th Jan 2014 11:45pm |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Yep...that was it! I had asked if I did a mirror on that drawing it would fit my 110...but then I realised that the air intake is on the same side whether it's a LHD or RHD!
Plz post the "after" pics! Nice job! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
29th Jan 2014 1:53am |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 |
This looks good, however...... that pipework entry on the wing has no water sump / drain, anything entering is going straight down like a water shoot!
We all like a splash, and many go wading. I see my air box has drain holes in the bottom, but I've read some block those up. |
3rd Feb 2014 5:23pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Well the adaptor is now in the final stages of build. Ive decuded to leave making a frame to hold tge snorkel and just drill through the windscreen frame work as today I inspected my air filter and it was drenched! So the snorkel will be fitted theis weekend.
However! I am having trouble removing the air box to do the air box modding. It seems I need to drill six rivets in the inner arch but id like some confirmation bwfore I drill something that didnt need drilling, Pgotos will follow tomorrow after ive sprayed the adaptor |
7th Feb 2014 10:25pm |
For the air box mod cutting the inside out, you could just use a hot knife while the air box is in place which will save the need for its removal.
Regards Pete. |
7th Feb 2014 10:58pm |
Thats not a bad tip, given that I have air con and all my research is telling me to remove air con pipe or the inner arch, I may opt for the in situ idea, cheers,
7th Feb 2014 11:07pm |
I'm just fabricating another version of this (more later IF it works) - but I was a bit concerned about fatman saying:
"After the airbox mod,i think it lost some "sweetness" somewere between 1600 and 1800 rpm,definatly got noiser at 1800 rpm. " Before I take to the inside of the airbox with a Dremel, should I be worried? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
22nd Feb 2014 9:45pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2603 |
I got my indie to do the airbox mod during the annual service last week. He also sealed up the pipe connections.
Can't say I can tell the difference though, but will watch the consumption -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
23rd Feb 2014 10:15am |
Please could someone tell me where I can get the diaphragm thingy to fit under the air box valve in the middle of this photo:
[URL=] Click image to enlarge[/URL] I have no idea what it's called. Cheers Matt Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
23rd Feb 2014 2:55pm |
I dont think ive seen many with this actually fitted, ill keep my eyes out for you and see if I can get one.
Pete |
23rd Feb 2014 3:25pm |
Thanks Pete - I had thought about just blocking it off but I'd still like the water to drain Tell someone you love them today because life is short.
23rd Feb 2014 5:18pm |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 |
I ment that i lost some of the gains i got from the hose replacement. Now i installed a bigger hose (102mm) and breathes right,we did the same thing to "Pouf's" stock puma http://www.defender2.net/forum/post308891.html#308891 and he also felt the gains,especially low down the rev range. |
24th Feb 2014 12:40pm |
Aaaah Tell someone you love them today because life is short.
24th Feb 2014 1:56pm |
andre.prum Member Since: 24 Feb 2014 Location: Bridel Posts: 8 |
I can't unfortunately see the picture added to your message.
Would you mind posting it again so that I can see how you modified the air box. Thanks in advance
28th Feb 2014 9:12pm |
