Home > Puma (Tdci) > Puma EGR blanking plate FREE :-) |
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 |
Which scangauge did you get Verdone and where did you get it from? I would like to be able to clear and check my own fault codes as well?
Cheers BB 2019 MY Disco 5 HSE Lux Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
23rd Jun 2008 7:54am |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 |
Lo bogblaster,
I got it from scangauge.net i think which is a greek retailer, but for the uk u might try these ones. http://www.scangauge.com/buy/uk.shtml Its the scangauge 2 with the xgauge features or whatever Greetings Verdone |
23rd Jun 2008 6:51pm |
Cheers for that Verdone, they are only 20 miles from me! What exactly does yours do when plugged into the Defender? Does it do MPG, trip mileage etc? I have been looking at this one http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...otohosting, but not sure if it is the right thing.
Any advice happily received! 2019 MY Disco 5 HSE Lux Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
23rd Jun 2008 9:18pm |
The one u r looking at is way more advanced, mine is like a more simple version of it, depends what u want out of it tbh, like yours will have the ability to plug into ur pc and watch cool graphs etc
Mine is a more simple version, doesnt plug into a pc, so i cant see shiny graphs, it show alot of stuff though like tripmeter, mpg, rpms, motor temperature etc etc i havent looked very closely into it because all i needed it for was searching for the fault and clearing it, so all in all it depends what u need and then see whats on the market, the thing is the one u showed will work perfect aswell since the new ford engine with the new ecu doesnt use a special obd2 dialect like the td5 did so u should be fine Anyways im not rlly a expert on the matter, but if any more question ask me on pm so we dont litter pete's topic Greetings Verdone |
23rd Jun 2008 9:45pm |
I've met Pete and a PROPER bloke he is to , I am sure he won't mind us bumping his thread to the top! We both have blanking plates, mine was initially a tight arsed home made jobby that I put on the other valve so much more complicated to fit, and I have promised him that I will also blank off the other side purely for research purposes I have stopped the surging by putting my home made in, but there is still a little bit of reluctance to pull from 70 mph in 6th, if you drop it down to 5th it pulls all the way through to 80 mph and then into 6th and on to 101 mph on the runway of my local aerodrome. So maybe after blanking off the one he recommends it will even better 2019 MY Disco 5 HSE Lux
23rd Jun 2008 10:00pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Thanks for the kind words Bogblaster
And yes keep bumping the thread as much collective info we can gain on this beast the better for us all. Regards and thanks pete. PS im looking into a cheap basic scan tool and live data logger for this car because i belive it may help there owners, i should have some answers soon hopefully. Ill keep you posted. ALSO what do you all think about switchable remaps on your pumas ??? you can have a bellautos standalone gadget that will program thecar from tuned to standard as many times as you wish at your will. Ill prob start another thread on this one so i can keep track easer. |
23rd Jun 2008 10:43pm |
From what i gather on msn he is indeed a good man , and regarding the thread i found it linked on a french forum , translated into french ofcourse Anyways i'll keep u guys updated on how it goed but i dont expect anymore little stupid light problems Greetings Verdone |
23rd Jun 2008 10:47pm |
Bogblaster i forgot to ask , how is the car going with the map on ?? Any warning lamps on etc etc.
Regards Pete |
23rd Jun 2008 11:00pm |
Going well Pete, no fault lights and pulling beter than the tune you overwrote 2019 MY Disco 5 HSE Lux
24th Jun 2008 8:56am |
Cool , thanks m8
24th Jun 2008 9:27am |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 280 |
Hi Pete, any more news on how we can get the fault lamp off while leaving the EGR plate in?
Verdone can you use the Scan Guage to permanatly correct the fault caused by the EGR plate? Thanks Rich |
24th Jun 2008 8:51pm |
The fault verdone has is air flow so itmust have some relevence , but i have seen this same fault mny many times on other cars even in standard form. Im still working on it m8 , sorry for been so slow but with it been show season its manic at my garage at the moment. Regards pete |
24th Jun 2008 9:03pm |
Fault has returned, so i either delete it again, but thats just crap, so i'm gonna dril a 5mm hole in the blanking kit for now.
Since its a ford engine i went on ford forums and they said drilling a 5mm hole in it will still fool the egr but the light wont come on? Greetings Verdone |
24th Jun 2008 9:06pm |
its worth a try and i think a good test to be made Regards Pete |
24th Jun 2008 9:09pm |
