![]() | Home > Maintenance & Modifications > Smith Allen 5w-30 oil |
Landy49 Member Since: 29 Feb 2024 Location: Hampshire Posts: 59 ![]() ![]() |
Has anyone bought this oil for their defender 2.2 it appears to be the correct variant just want to confirm?
This is the link below https://www.ebay.co.uk/itm/373537080258 |
Would the quality not be as good then?
I always bought Mobil but now seems very hard to find or if you do it’s very expensive |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4331 ![]() ![]() ![]() |
I don't know anything about Smith Allan, but the fact they are just a blender isn't necessarily a bad thing. 2007 110 TDCi Station Wagon XS
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 85 ![]() ![]() ![]() |
I use this Smith & Allen oil in the L322 and D4 and have never had an issue.
It's even cheaper if you buy it 20l at a time. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 231 ![]() ![]() ![]() |
I've been using them for a while now as it's easy and cheap to order no complaints but I change my engine oil every 6k miles in my Td5 and other oils every year depending on use 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
Thanks for all the above will get some ordered
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1052 ![]() ![]() ![]() |
Prices on the 20L drums are fantastic..! They’ll have an order off me. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 170 ![]() ![]() ![]() |
Smith & Allen are a good lubricant company.
Used them for all sorts on my land rovers over the years and also run a lot of our farm/plant equipment with it. I’m a bit of an oil snob and OCD gets the better of me with my 90 now, so I run Swepco in the g/box, t-fer box, diffs etc. and Fuchs titan 5/40 meeting VW 505 01 spec for the engine. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
It’s always hard to judge how well an engine oil has performed without robust scientific testing over long periods of its use in real world engines over many miles and years. Even then it may perform better or worse in different engines so it’s very hard to judge if it’s the best oil for our particular engines..
We end up relying on good specifications, hopping they are sufficiently robust and applicable to our engines and driving patterns. Plus rely on the manufacturers to constantly and consistently adhere to or exceed those specifications in the products they supply. Hence I look for a reputable manufacturer, with positive feedback, who have been in business for a longtime, meet the spec for my engine and supply at a reasonable price. I also believe that changing oils more frequently makes the biggest difference, especially engine oil for a 2.2 that has a DPF. Smith and Allen seem to meet my criteria and their C1 2.2 spec oil is a very good price, especially in a 20 Litre can. This makes it ideal for those like me that change their oil at circa 5k miles intervals. So I will do a little more research on them and if happy order a 20 Litre can. PS M94PUMA - I’m assuming you are not running a 2.2 if you are using that spec engine oil as it’s not a C1 low SAPs oil suitable for a 2.2. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1328 ![]() ![]() ![]() |
Apart from checking the specification beyond viscosity rating, which we assume are independently verified, the difference between a high and less high quality oil must be in the longevity (miles change interval).
The question then is how much longer can you run a high quality oil and do you do you have the balls to do that (20k miles everyone?). I think most of us will chicken out and prefer a shorter interval in which case you can ask if it's worth paying for a premium branded oil? |
If there's any uncertainty, you could always run it for a period, say half the service interval, and then have an oil analysis done. That'll tell you if it's still in-grade, levels of wear metals etc. Costs about £40. 2007 110 TDCi Station Wagon XS
