![]() | Home > Maintenance & Modifications > Smith Allen 5w-30 oil |
Landy49 Member Since: 29 Feb 2024 Location: Hampshire Posts: 59 ![]() ![]() |
Has anyone bought this oil for their defender 2.2 it appears to be the correct variant just want to confirm?
This is the link below https://www.ebay.co.uk/itm/373537080258 |
Would the quality not be as good then?
I always bought Mobil but now seems very hard to find or if you do it’s very expensive |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4330 ![]() ![]() ![]() |
I don't know anything about Smith Allan, but the fact they are just a blender isn't necessarily a bad thing. 2007 110 TDCi Station Wagon XS
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 85 ![]() ![]() ![]() |
I use this Smith & Allen oil in the L322 and D4 and have never had an issue.
It's even cheaper if you buy it 20l at a time. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 231 ![]() ![]() ![]() |
I've been using them for a while now as it's easy and cheap to order no complaints but I change my engine oil every 6k miles in my Td5 and other oils every year depending on use 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
Thanks for all the above will get some ordered
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1051 ![]() ![]() ![]() |
Prices on the 20L drums are fantastic..! They’ll have an order off me. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 170 ![]() ![]() ![]() |
Smith & Allen are a good lubricant company.
Used them for all sorts on my land rovers over the years and also run a lot of our farm/plant equipment with it. I’m a bit of an oil snob and OCD gets the better of me with my 90 now, so I run Swepco in the g/box, t-fer box, diffs etc. and Fuchs titan 5/40 meeting VW 505 01 spec for the engine. |
