![]() | Home > Puma (Tdci) > Engine stopping instantly when turned off? |
Doobsn Member Since: 18 Jan 2023 Location: Bavaria Posts: 14 ![]() ![]() ![]() |
Hello Jim,
I am facing the same issue with mine and I am not sure if this was always the case. I had to swap the engine years ago and recognized this shut off behaviour some time ago. My mechanic, I sent him a video, is not sure, if this is normal, in another forum the people suggested to check the injectors which could drip. To check this I need to take them out and let them check at a Bosch Service. I haven't done that. I will keep you updated, would be great if you could do the same. Cheers Tobias |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 998 ![]() ![]() ![]() |
Hi Tobias
So I'm not going mad then ![]() The vehicle is well maintained and serviced regularly. It runs like a dream and he always uses premium diesel. Have you had any fault codes thrown up? What about adding some injector cleaner to clean the injectors? Jim |
Hello Jim,
My TD4 (2013 Model) is also well maintained and serviced. Premium Diesel when available and injector cleaner Done 3 weeks ago. I will keep you updated After my mechanic having a Look into it. Cheers |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3640 ![]() ![]() ![]() |
The 2.2 should close the throttle body the instant you turn the ignition off. This is turn creates a vacuum at intake, and not allow the piston to create good compression. The result is a smooth switch off of the engine which might take a bit longer to stop. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Dinnu
That's the way my 2.2 shuts down when I switch the ignition off. I haven't mentioned anything to my buddy as I honestly thought that I was imagining things. I guess that we will have to wait for Tobias to have his Puma investigated to find out what would cause an instant shut down. Jim |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 217 ![]() ![]() |
is it the same as this:
https://www.defender2.net/forum/topic50342.html |
Hi Jerry
No. No shuddering just when you turn the key off its an instant shut down. Jim |
Hello,
I will see my mechanic, he will see my Defender End of August, so there will be not a quick answer. I read the thread about shuddering and would say, mine is not doing that, that running for a second longer after switching off. Driving a car with so many noises and then getting suspicious about the engine noises ![]() Cheers |
