![]() | Home > Puma (Tdci) > 2.2 'shudder' and vibration of gearstick when switching off |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
Happens to mine too. Was meaning to ask about it. Don't know if it's right or not but it's very weird. When it happens it seems like the engine isn't turning off immediately either but keeps going for like a fraction of a second or so.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
It's just centrifugal inertia, it's not a 1L engine after all. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
MikeJ Member Since: 04 May 2014 Location: Dorchester, Dorset Posts: 41 ![]() ![]() ![]() |
I've noticed this a small number of times and it only happens when it's been idling for a while.
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Our Td5 does it too. I speculated it was maybe the balancing weight of the dual mass flywheel moving to and fro until it doesn't counteract with the springs anymore.
Greetings, Joris |
adminkatana Member Since: 11 Apr 2016 Location: Sussex Posts: 31 ![]() ![]() ![]() |
Thanks for input, glad to hear it's nothing to worry about!
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 212 ![]() ![]() |
I think that a few of us have also got this shuddering (I think I described it as an abrupt clunk, but shudder is more accurate)
see thread: http://www.defender2.net/forum/topic45073.html I was wondering if it happened whilst stopping the engine mid-cycle of a regeneration. but others have suggested alternative thoughts. |
Beery Member Since: 16 Nov 2014 Location: NSW Posts: 36 ![]() ![]() ![]() |
Its a normal thing for a diesel, because of the high compression ratio. However, modern diesels have a throttle valve at the entrance to the intake manifold and has a couple of purposes. Firstly its used to create a pressure drop to enable high rates of EGR, secondly, it closes when the engine is shut off to cut the air supply ao there is nothing for the pistons to compress and prevent the typical diesel rock.
For some reason, sometimes this throttle doesnt shut when the engine is stopped. Nothing to do with DPF regen, as mine is non DPF and does the same thing sometimes. |
