Home > Puma (Tdci) > 2.2 'shudder' and vibration of gearstick when switching off
adminkatana
United Kingdom 2015 Defender 90 Puma 2.2 CSW Keswick Green
Hi all,
About every 1/10 trips when switching the off (handbrake on, neutral, clutch out, rested idle for 30secs or so) the Defender will shudder and shake as the engine switches off. The gearstick also vibrates a fair bit.
Happens sporadically in different locations/ after different lengths of drives, starts fine next time it's used. Is this normal?
I recently did the LR Experience and mentioned it to our instructor (who also owned a 90) and said he'd never heard of it.
Appreciate anyones thoughts. Thanks!
Post #576019 7th Nov 2016 12:36pm
dantastic
Happens to mine too. Was meaning to ask about it. Don't know if it's right or not but it's very weird. When it happens it seems like the engine isn't turning off immediately either but keeps going for like a fraction of a second or so.
Post #576022 7th Nov 2016 12:59pm
It's just centrifugal inertia, it's not a 1L engine after all. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #576027 7th Nov 2016 1:55pm
MikeJ
United Kingdom 2013 Defender 130 Puma 2.2 HCPU Fuji White
I've noticed this a small number of times and it only happens when it's been idling for a while.
Post #576030 7th Nov 2016 1:59pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Our Td5 does it too. I speculated it was maybe the balancing weight of the dual mass flywheel moving to and fro until it doesn't counteract with the springs anymore.
Greetings,
Joris
Post #576038 7th Nov 2016 2:40pm
adminkatana
Thanks for input, glad to hear it's nothing to worry about!
Post #576043 7th Nov 2016 3:03pm
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
I think that a few of us have also got this shuddering (I think I described it as an abrupt clunk, but shudder is more accurate)
see thread:
http://www.defender2.net/forum/topic45073.html
I was wondering if it happened whilst stopping the engine mid-cycle of a regeneration. but others have suggested alternative thoughts.
Post #576145 7th Nov 2016 11:36pm
Beery
Australia 2015 Defender 130 Puma 2.2 HCPU Corris Grey
Its a normal thing for a diesel, because of the high compression ratio. However, modern diesels have a throttle valve at the entrance to the intake manifold and has a couple of purposes. Firstly its used to create a pressure drop to enable high rates of EGR, secondly, it closes when the engine is shut off to cut the air supply ao there is nothing for the pistons to compress and prevent the typical diesel rock.
For some reason, sometimes this throttle doesnt shut when the engine is stopped.
Nothing to do with DPF regen, as mine is non DPF and does the same thing sometimes.
Post #576163 8th Nov 2016 1:49am
