Home > Puma (Tdci) > Engine stopping instantly when turned off?
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi all
I may be going insane, but hear me out..
A friend with a 2014 2.2 Defender Puma gave me a lift yesterday. I noticed that when he switched the engine off that it was instant compared to my 2013 that takes maybe a second before its fully off.
Now I've checked with my other car and my wife's car and neither of those shut off instantly either. they have a second when the engine shuts its self down.
Should there be a second or so delay as the engine stops when turned off at the ignition?
Am I going mad? Shocked
Jim
Post #1071953 22nd Jul 2025 5:18am
Doobsn
Germany 2013 Defender 110 Puma 2.2 SW Orkney Grey
Hello Jim,
I am facing the same issue with mine and I am not sure if this was always the case.
I had to swap the engine years ago and recognized this shut off behaviour some time ago.
My mechanic, I sent him a video, is not sure, if this is normal, in another forum the people suggested to check the injectors which could drip. To check this I need to take them out and let them check at a Bosch Service. I haven't done that.
I will keep you updated, would be great if you could do the same.
Tobias
Post #1071957 22nd Jul 2025 7:03am
jim4244
Hi Tobias
So I'm not going mad then Laughing
The vehicle is well maintained and serviced regularly. It runs like a dream and he always uses premium diesel.
Have you had any fault codes thrown up? What about adding some injector cleaner to clean the injectors?
Jim
Post #1071966 22nd Jul 2025 8:44am
Doobsn
Hello Jim,
My TD4 (2013 Model) is also well maintained and serviced.
Premium Diesel when available and injector cleaner Done 3 weeks ago.
I will keep you updated After my mechanic having a Look into it.
Post #1071967 22nd Jul 2025 9:10am
Dinnu
The 2.2 should close the throttle body the instant you turn the ignition off. This is turn creates a vacuum at intake, and not allow the piston to create good compression. The result is a smooth switch off of the engine which might take a bit longer to stop. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1071970 22nd Jul 2025 9:28am
jim4244
Dinnu
That's the way my 2.2 shuts down when I switch the ignition off.
I haven't mentioned anything to my buddy as I honestly thought that I was imagining things.
I guess that we will have to wait for Tobias to have his Puma investigated to find out what would cause an instant shut down.
Jim
Post #1071979 22nd Jul 2025 11:59am
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Post #1071983 22nd Jul 2025 12:51pm
jim4244
Hi Jerry
No. No shuddering just when you turn the key off its an instant shut down.
Jim
Post #1071985 22nd Jul 2025 1:03pm
Doobsn
Hello,
I will see my mechanic, he will see my Defender End of August, so there will be not a quick answer.
I read the thread about shuddering and would say, mine is not doing that, that running for a second longer after switching off.
Driving a car with so many noises and then getting suspicious about the engine noises Smile
Post #1071987 22nd Jul 2025 1:32pm
