Home > My Defender > 1995 110CSW Epsom Green to Keswick
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
This thread will follow the change of doors and journey of my Epsom Green 110CSW becoming a 110 CSW in Keswick Green (with black accent bits).
1st the new doors as the old ones looked like this (and this is probably the best of 4)
New doors were sourced and the painting began
Passenger front was the first to go on
Just the doorcard to go back on this one now, it was too hot yesterday to work in full sun at any sort of speed. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1071229 11th Jul 2025 12:38pm
bodstruck
Looking good Thumbs Up . And I like your painting stands.
I am sure you have it all thought through but....
If you are planning on taking off the infill panels behind the second row doors be prepared to have to repair the c pillars and possibly repair or replace the cross-member. Once you have gone to all the effort of renewing the doors and paint I would highly recommend Gwyn Lewis mud shields to keep the areas around the arches clean and slow down any future corrosion in these areas.
Good luck, looking forward to seeing the progress.
Post #1071232 11th Jul 2025 1:02pm
300TDi CSW Phil
I tidied up all that area and fitted the Gwynn Lewis mud shields front and rear a few years ago. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1071233 11th Jul 2025 1:05pm
300TDi CSW Phil
So the "Tart Up" continues.....
Time for the old drivers door or to be precise what is left of it to come off..
And the new door has gone on
Now to prep the 2nd row doors 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1071569 16th Jul 2025 3:50pm
landiedave
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
Where are you sourcing your doors?
Post #1071608 17th Jul 2025 2:50am
Screbble
Looks great - an excellent job!
Post #1071611 17th Jul 2025 6:42am
300TDi CSW Phil
The doors have come from DDS Metal Services in Coventry.
I'm not 100% sure that I have the correct version for the fronts though as I have had to make up a couple of brackets for the bottom of the window regulator panels but not a long job and the doors otherwise seem excellent. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1071614 17th Jul 2025 7:48am
300TDi CSW Phil
Thank you.
Hopefully I will be prepping and priming the 2nd row doors today. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1071615 17th Jul 2025 7:49am
300TDi CSW Phil
The second row doors are coming along.
Treated the galvanised frames first (and remembered to take a picture this time)
Then prepped and etch primer
And the 1st coat of filler primer
I'm hoping the weather lets me get the 2nd coat of filler primer on later. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1071720 19th Jul 2025 10:15am
300TDi CSW Phil
Trying to get the doors done and on for an upcoming trip so soldiering on when the weather (and work) permits.
Filler primer went on the 2nd row doors the other day...
so todays job was to flat it back and put the 1st top coat on
Will be turning them shortly to paint the outside. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1072079 23rd Jul 2025 5:27pm
300TDi CSW Phil
As stated on another post I bit the bullet so to speak on some LR Parts Aluminium door handles.
The finish is good but alas the sizing is a bit off and three don't have the door skin slot machined in.
With some auspicious use of an angle grinder and a steady hand two are now on and looking the part.
I was starting to think it was the cutouts in the doors but having measured the ones in the DDS front doors against the originals there is less than 0.5mm in it and the issue is more like 2mm Big Cry
The remaining ones (2nd row) will be dealt with as necessary but as they dont have locks may be slightly easier.
Anyway here is a picture of the passenger front fitted (the drivers and ignition/steering lock are also done but rain prevented me from hanging around to take pictures).
M0XQS
Post #1072132 24th Jul 2025 5:04pm
miker916
Scotland 2005 Defender 90 Td5 HT Belize Green
This looks great, I would love to have a go at this. Is this something anyone can do or are you a painter to trade with all the gear & equipment needed?
Post #1072134 24th Jul 2025 5:50pm
300TDi CSW Phil
Definitely not a painter and have ended up buying also sorts of prep gear etc in order to do the job.
It is being rollered on and seems to be pretty smooth as long as you get enough but not too much paint on.
The stand for painting the doors was about £20 worth of wood plus scraps and screws that I had already.
The big thing is not skipping degreasing and tack cloths before applying the paint and trying to miss the worst of the humidity. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1072135 24th Jul 2025 6:22pm
miker916
ah ok, i just assumed you were spraying them. They look brilliant, what a cracking job you are making of them. Staying in Scotland, the humidity might be an issue for me Laughing
Post #1072145 24th Jul 2025 10:12pm
Pickles
Great job, Keswick is the perfect color for a Defender IMHO.
Our 2013 Defender 90 which we ordered new was Keswick, & we specified an Indus Silver roof to go with the alloy wheels & chequreplate etc.
Post #1072214 25th Jul 2025 10:25pm
