Home > My Defender > 1995 110CSW Epsom Green to Keswick
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
This thread will follow the change of doors and journey of my Epsom Green 110CSW becoming a 110 CSW in Keswick Green (with black accent bits).
1st the new doors as the old ones looked like this (and this is probably the best of 4)
New doors were sourced and the painting began
Passenger front was the first to go on
Just the doorcard to go back on this one now, it was too hot yesterday to work in full sun at any sort of speed. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1071229 11th Jul 2025 12:38pm
bodstruck
Looking good Thumbs Up . And I like your painting stands.
I am sure you have it all thought through but....
If you are planning on taking off the infill panels behind the second row doors be prepared to have to repair the c pillars and possibly repair or replace the cross-member. Once you have gone to all the effort of renewing the doors and paint I would highly recommend Gwyn Lewis mud shields to keep the areas around the arches clean and slow down any future corrosion in these areas.
Good luck, looking forward to seeing the progress.
Post #1071232 11th Jul 2025 1:02pm
300TDi CSW Phil
I tidied up all that area and fitted the Gwynn Lewis mud shields front and rear a few years ago. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #1071233 11th Jul 2025 1:05pm
300TDi CSW Phil
So the "Tart Up" continues.....
Time for the old drivers door or to be precise what is left of it to come off..
And the new door has gone on
Now to prep the 2nd row doors 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #1071569 16th Jul 2025 3:50pm
landiedave
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
Where are you sourcing your doors?
Post #1071608 17th Jul 2025 2:50am
Screbble
Looks great - an excellent job!
Post #1071611 17th Jul 2025 6:42am
300TDi CSW Phil
The doors have come from DDS Metal Services in Coventry.
I'm not 100% sure that I have the correct version for the fronts though as I have had to make up a couple of brackets for the bottom of the window regulator panels but not a long job and the doors otherwise seem excellent. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #1071614 17th Jul 2025 7:48am
300TDi CSW Phil
Thank you.
Hopefully I will be prepping and priming the 2nd row doors today. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #1071615 17th Jul 2025 7:49am
300TDi CSW Phil
The second row doors are coming along.
Treated the galvanised frames first (and remembered to take a picture this time)
Then prepped and etch primer
And the 1st coat of filler primer
I'm hoping the weather lets me get the 2nd coat of filler primer on later. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #1071720 19th Jul 2025 10:15am
