![]() | Home > My Defender > 1995 110CSW Epsom Green to Keswick |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1002 ![]() ![]() |
Looking good
![]() I am sure you have it all thought through but.... If you are planning on taking off the infill panels behind the second row doors be prepared to have to repair the c pillars and possibly repair or replace the cross-member. Once you have gone to all the effort of renewing the doors and paint I would highly recommend Gwyn Lewis mud shields to keep the areas around the arches clean and slow down any future corrosion in these areas. Good luck, looking forward to seeing the progress. |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 804 ![]() ![]() ![]() |
I tidied up all that area and fitted the Gwynn Lewis mud shields front and rear a few years ago. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
So the "Tart Up" continues.....
Time for the old drivers door or to be precise what is left of it to come off.. ![]() Click image to enlarge And the new door has gone on ![]() Click image to enlarge Now to prep the 2nd row doors 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
landiedave Member Since: 14 Mar 2013 Location: Welsh Marches Posts: 60 ![]() ![]() ![]() |
Where are you sourcing your doors?
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2272 ![]() ![]() ![]() |
Looks great - an excellent job!
The doors have come from DDS Metal Services in Coventry. I'm not 100% sure that I have the correct version for the fronts though as I have had to make up a couple of brackets for the bottom of the window regulator panels but not a long job and the doors otherwise seem excellent. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
Thank you. Hopefully I will be prepping and priming the 2nd row doors today. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
The second row doors are coming along.
Treated the galvanised frames first (and remembered to take a picture this time) ![]() Click image to enlarge Then prepped and etch primer ![]() Click image to enlarge And the 1st coat of filler primer ![]() Click image to enlarge I'm hoping the weather lets me get the 2nd coat of filler primer on later. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
