Home > My Defender > 1995 110CSW Epsom Green to Keswick
Page 2 of 2 <12
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
More Defendering done today.
Got the 2nd row drivers side door on but can't for the life of me get the replacement door card clips to work so a more industrial solution is being worked on.
Here is the Drivers side with it's 2 new doors.
And as a little deviation and as shelf space is always an issue when camping this got finished.
Hopefully tomorrow the 2nd row passenger side will go on and the 2nd row door cards will get fitted. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1072253 26th Jul 2025 8:41pm
300TDi CSW Phil
The last of the doors is now on and on the plus side I didn't have a series of impromptu showers today.
I did however struggle with the 30 year old bolts through the B pillar and at least one of the hinges only has hinge pin left in one end of the tongue so the hinges were definitely due a change.
Out of the four bolts 2 came out with an impact driver, one came out with a stud extractor and the fourth one eat the stud extractor for breakfast and left me scratching my head for a while, thankfully it was on the top hinge so I ended up drilling it out from the rear.
The bottom captive nut plate had to be extracted and straightened as using the impact driver on it bent it somewhat and the new bolts wouldn't both find the thread. It is not as much of a nightmare to get to as I was expecting.
Anyway you all want to see the photo of the passenger side with both of its new doors so.....
There wont be much progress over the next week or so as we are going to be using it for a change instead of working on it.
Hopefully the doorcards will go in tomorrow afternoon/evening and if it goes to plan I will put a quick picture up of that ...... as a teaser I will say it involves rivnuts and stainless steel dome head machine screws. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1072306 27th Jul 2025 6:51pm
300TDi CSW Phil
I did manage to get the 2nd row door cards in today with my slightly more industrial plan than the original plastic clips on plastic clips into rubber thingy wotsits.
It turns out the holes in the door for the rubber grommets are the perfect size for M5 Rivnuts.
The door cards drill ok with decent drill bits with wood on the face as a backer and drilling through what was left of the plastic bits on the rear.
I decided that 7 flanged dome head M5's would be more than sufficient to replace the 12 plastic clips (and one or two bolts would have to be very long for M5's, if they rattle I can always unscrew them and add a couple more here or there.
Anyway a couple of pictures.
A couple of the flanges on the hinge side are a bit close to the edge and I may in time pack the back out with some grey epoxy putty if it bugs me too much. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1072394 28th Jul 2025 9:41pm
L110CDL
Great work you've done with the new doors Thumbs Up Clayton.
Keeper.
Post #1072777 4th Aug 2025 3:12pm
300TDi CSW Phil
Thanks Clayton.
This week away is also proving the new auxiliary electrical system and I am pretty sure I can get away with upgrading the 8 or so year old USB sockets for fast charge/USB C PD ones. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1072789 4th Aug 2025 5:06pm
300TDi CSW Phil
Now back from various trips so it was time to get back on the colour conversion.
Spoiler alert nothing has changed colour today...
So the chequer plate (a previous owner had a fetish for the stuff) was going to get in the way of painting the wing tops, sills and rear quarters so there was only one solution.
This is what it looked like before I took a drill to the rivets.
And a few of afterwards including I suspect the reason it had Chequer plate sill covers.
I was thinking that I may put Rivets in the holes in the sills and then paint them black doing away with the chequer plate but at some point the rear of the drivers side has had some unwanted attention.
I could by a rear sill section and replace just that part but then it would look odd that it doesn't have the rivets that the other parts have.
Another solution is to replace both the sills complete but that wasn't factored into doing this (as other things weren't but became non optional).
Alternatively I stick with plan A which was to paint it black and put it back on. Which I already have the paint for and had budgeted for black rivets already.
I have no plan to remove the other minor dents that the vehicle has but to leave this one on display is a bit much. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1073699 19th Aug 2025 4:16pm
bodstruck
I needed to replace the sills on my old puma. I bought a secondhand set on ebay for less than £50.
I did away with them on my tdi in favour of rock sliders but if you want to keep the steps and sills perhaps replace the whole lot?
https://ebay.us/m/S9xJHo
Post #1073706 19th Aug 2025 5:32pm
300TDi CSW Phil
I'm putting the chequer plate back but in black.
Todays progress...
The eldest boy pressure washed the chequer plate and took a photo of me decal removing
And then it was more naked with all the decals removed
Courtesy of a plastic razor blade handle and blades combined with a removing wheel in a couple of places, it was actually a bit quicker and easier than I thought.
Then on to etch priming the chequer plate
By tomorrow night (weather permitting) the chequer plate will be black and waiting for the body to change colour. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1073924 22nd Aug 2025 5:50pm
300TDi CSW Phil
Today is chequer plate day..... no not fitting it still got the wings and tub to paint etc. But as it was off and cleaned and primed it was time to apply the uber sticky matt black raptor to it.
One coat on the reverse...probably overkill but it makes sure there are no silver edges.
Then two coats on the facing sides......
Now to concentrate on the main bodywork. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1074043 25th Aug 2025 4:20pm
L110CDL
Great work your doing on the 110, making the most of the weather with all that painting as well Very Happy Clayton.
Keeper.
Post #1074180 27th Aug 2025 8:54pm
300TDi CSW Phil
The combination of the weather and work have halted changing the colour on anything.
But that shouldn't stop progress so I ordered one of these for the back, I know not age relevant but I like them and the landy is fairly non standard including the new colour in terms of age, the old skool of this may offset the more recent than age colour or cause purists to faint Shocked
I've also ordered a black and silver oval for the radiator grille (hasn't arrived yet)
And a pair of Mud interior lights (also not arrived yet) to brighten that up in the coming darker months of the British climate. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1074330 29th Aug 2025 6:50pm
300TDi CSW Phil
Again the british weather is not conducive to painting but a box arrived from Mudstuff Very Happy and an envelope arrived from ebay.
First job was to admire the black and silver grille badge
Enough of that here is a picture of the now working rear interior light after cleaning the door switches in an ultrasonic cleaner.
I always hated the look of the LED panels and they were always dropping and sitting on the lenses
The rear needed a negative flylead made up as the original fitting got it from a screw in the centre rib of the roof into the backplate and through the nuts.
So this happened
And the front got the same treatment but without the need for the plinth (and the before photo Big Cry )
And I suspect with the rain that concludes Defendering. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1074376 30th Aug 2025 4:44pm
L110CDL
Nice light upgrades there and the black and silver badge is just right on the front grill Thumbs Up Clayton.
Keeper.
Post #1074833 5th Sep 2025 8:22pm
Page 2 of 2 <12
