Home > Puma (Tdci) > Remote remaps - Bell Auto Services, Alive or Empire?
Page 2 of 2 <12
Ianh
BobGFish - The how to guide for the 2.2 inlet elbow replacement .https://www.defender2.net/forum/topic81674.html?highlight=elbow
Post #1071565 16th Jul 2025 2:53pm
BobGFish
Switzerland 2014 Defender 110 Puma 2.2 SW Indus Silver
Thanks so much for that link. Helpful. I just can't undo the bolts on the metal air intake hose...Maybe time for new spanners Very Happy
Post #1071588 16th Jul 2025 5:49pm
hank
Landymatt wrote:
I chickened out and left it on 150… I didn’t upgrade the intercooler or anything so was worried about over-stressing something, especially when towing the odd heavy thing
Do it Twisted Evil > 110 XS Double Cab
Post #1071648 17th Jul 2025 9:07pm
HardCharger
I went with BAS 170. Also had the immobilizer deactivated (a lot of interference non-starting experienced so to improve reliability, had that removed. Defender thefts are not an occurrence here), then EGR delete to save my newly rebuilt engine, and speed adjustment. Thumbs Up No Better Friend, No Worse Enemy
Post #1071657 18th Jul 2025 4:30am
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
I have 2015 2.2 UXS on 55k, Ive had it just over a year and love it. Ive never found it lacking in power but I do get the kangaroo effect when cold if I dont add the Millers fuel additive.
The garage that maintains it tell me they think its remapped already as the owner has a 2016 2.2 UXS and he said mine drives similar to his and he has a stage 1 remap already.
MPG wise I get on average around 25. Best I have had is 28 worst it 22. For the record I dont drive it hard and usually sit at 65- 70mph when on the motorway.
Based on the above I am wondering if the remap on it is not a good one and so am considering getting someone like BAS to put their stage 1 map on it. I just wondered what others would think based on the above? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1071669 18th Jul 2025 10:48am
Ianh
Before doing a map change the air intake from the wing to the air-box for a large bore pipe. The standard air intake pipework is highly restrictive and convoluted. Also look at the airbox mod to improve airflow more.
Once done you may find your vehicle is performing the way you want without a map.
Post #1071671 18th Jul 2025 12:23pm
BobGFish
IanH
What would you recommend? Is there something on the market that works well?
Post #1071672 18th Jul 2025 12:39pm
Beco90
Hi Bob,
Ian’s reccomendation is also something I’m looking at. I believe the only options on the market atm is the Nakatanenga optimised air intake, or their raised air intake. Or one from Allisport but that’s quite expensive comparatively. Nugget Stuff used to offer one but I believe he has now retired.
If you want to keep the factory air filter, best to stick with the Nakatanenga option I think? Quite a few positive reviews/accounts on here.
https://www.4x4overlander.com/product/naka...ender-td4/
https://www.lrparts.net/as293-cylinder-air...sport.html
Post #1071676 18th Jul 2025 2:24pm
BobGFish
Yeah. I've seen the Nakatanenga one. I have a LHD. So my air intake is lower right side and then the fans heater box etc is the one on top of wing on the right. Was thinking about adding a raised air intake later. I prefer the aesthetics of it it coming from the lower right rather than on top of the wing. Wonder if the Naka can come from original air intake instead? By the way Pete from BAS did not recommend an raised intake as it does restrict flow to much.
Post #1071685 18th Jul 2025 4:53pm
HardCharger
Since Nuggetstuff is sadly no longer operating, I bit the bullet and went with the AlliSport waterproof air intake kit. Paired it with the Naka SN4 RAI kit that feeds through the top of the wing. It came, for LHD units, a bit that replaces the ducting with an intake where the original intake was and a hose and assembly that bolts into the blower intake. It gets rid of the gap problem, I think. Still have to do a proper shake down which is scheduled on Wednesday, weather permitting. We're experiencing strong typhoon at the moment here. No Better Friend, No Worse Enemy
Post #1071850 21st Jul 2025 5:38am
The Nakatenga RAI is substantially larger bore than any other commercially available alternatives (at least that I am aware of) and appears not to restrict airflow at all. I don't think Pete Bell tested a Nakatanenga snorkel, only the more common (and highly restrictive) offerings. The difference I found when I fitted my Nakatanega RAI was immediate and significant.
Nakatanenga makes version of these for both wing-side mounting (link) and wing-top (link) mounting and either is available in forms for mounting to a roll-cage or mounting to the windscreen pillar. Nakatanenga's website is not great so make sure if you do order from it that you are ordering the one you want. I also think that for a LHD vehicle you may have to use the wing-side intake since the heater box is on the same side of the vehicle as the air intake (on RHD vehicles they are opposite), alternatively it might be possible to relocate the heater intake to the lower, wing-side, opening.
There really is no point in fitting either if you don't also replace the standard air filter box with a less-restrictive one, and with the demise of the Nuggetstuff offering your only choices really are to modify the stock unit (not ideal, it is still not great) or to go with the Allisport product.
A Nakatanenga RAI with an Allisport air filter will improve the performance of your engine noticeably.
As noted in earlier posts above, there is no point remapping your vehicle if you do not do something about the disaster that is the standard duct from the wing to the airbox. It is such a poor design you would struggle to come up with something worse. The airbox is not much better in standard form.
Post #1071878 21st Jul 2025 11:15am
andy63
Well I'm at odds with BW and some of his comments..
Not quite the same bits , but my findings after fitting an alisport air box to 2.2tdci was that the stock air box even with the water separator impeller left in place was more efficient , as supported by mass air flow data and scope data..
It was measurable, as was the changing of the standard ducting from wing to air box with large bore reinforced air hose ..again measurable but not as significant as the swapping of air boxes
All my figures were obtained with a safari raised intake fitted so can't comment on what difference that makes, but it can certainly cope with the demands of a mapped engine and standard turbo..
Fitting a centrifugal pre cleaner to the top of the raised intake made no measurable difference to the maf figures which surprised me....
All that borne out by scan tool data on mass air flow and engine volumetric efficiency figures..and scope data on the maf sensor...
I phoned ali sport just out of curiosity, and even though I'd seen claims of their box improving engine power they said its main benefit was primarily a secure sealed intake system rather than power benefits...
Post #1071881 21st Jul 2025 11:47am
Page 2 of 2 <12
