![]() | Home > Td5 > Constant hum from 50mph upwards |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Wheel bearing??
Any noise change with steering inputs? |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1046 ![]() ![]() ![]() |
Tyres,wheel bearing, binding brake? 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS. |
revd Member Since: 20 Apr 2024 Location: England Posts: 276 ![]() ![]() |
Tyres? Significant damage to tread or sidewall even if holding pressure
Drain the front differential and strain the oil that comes out |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
The tread noise if big treads or bearing would be my guess
Jack up and give them a spin 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 988 ![]() ![]() ![]() |
Change diff fluid (in my experience it is the most likely culprit). If no change in hum, check front wheel bearings.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 567 ![]() ![]() ![]() |
Tyres starting to wear unevenly would be my first guess. Try swapping front to back. 1983 110 automatic OM606
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 878 ![]() ![]() ![]() |
Bizarrely I had this yesterday on my D2 (also TD5). I had put it down to the recently fitted roof rack but found that it goes away over 60mph. No discernable vibration through the steering wheel. Will investigate later and report back in case it helps diagnose yours. 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
After changing the n/s front wheel bearings (where it appeared the noise was coming from), there was no change. I then swapped the o/s as I was on a roll and the problem has gone!
