Home > Td5 > Constant hum from 50mph upwards
camelman
Right then, TD5 (130) with standard gearing and no lift.
when speed approaches 50mph get a very loud hum starting, appearing to come from the front of the vehicle. Gets louder up to 60, below 45mph all is normal.
Taking the vehicle out of gear and coasting downhill has no effect so it is directly related to roadspeed and not changing under load.
Anyone else had this before I start swapping front axle bits out?
Post #1070456 27th Jun 2025 10:42pm
landy andy
Wheel bearing??
Any noise change with steering inputs?
Post #1070466 28th Jun 2025 5:14am
BrickBox
Tyres,wheel bearing, binding brake? 2008 2.4 110 Utility Station Wagon XS.
Post #1070467 28th Jun 2025 6:31am
revd
Tyres? Significant damage to tread or sidewall even if holding pressure
Drain the front differential and strain the oil that comes out
Post #1070470 28th Jun 2025 8:04am
bear100
The tread noise if big treads or bearing would be my guess
Jack up and give them a spin 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1070471 28th Jun 2025 8:06am
