Home > Td5 > Constant hum from 50mph upwards
camelman
Right then, TD5 (130) with standard gearing and no lift.
when speed approaches 50mph get a very loud hum starting, appearing to come from the front of the vehicle. Gets louder up to 60, below 45mph all is normal.
Taking the vehicle out of gear and coasting downhill has no effect so it is directly related to roadspeed and not changing under load.
Anyone else had this before I start swapping front axle bits out?
Post #1070456 27th Jun 2025 10:42pm
landy andy
Wheel bearing??
Any noise change with steering inputs?
Post #1070466 28th Jun 2025 5:14am
BrickBox
Tyres,wheel bearing, binding brake? 2008 2.4 110 Utility Station Wagon XS.
Post #1070467 28th Jun 2025 6:31am
revd
Tyres? Significant damage to tread or sidewall even if holding pressure
Drain the front differential and strain the oil that comes out
Post #1070470 28th Jun 2025 8:04am
bear100
The tread noise if big treads or bearing would be my guess
Jack up and give them a spin 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1070471 28th Jun 2025 8:06am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Change diff fluid (in my experience it is the most likely culprit). If no change in hum, check front wheel bearings.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1070708 2nd Jul 2025 7:56pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Tyres starting to wear unevenly would be my first guess. Try swapping front to back. 1983 110 automatic OM606
Post #1070726 3rd Jul 2025 6:08am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Bizarrely I had this yesterday on my D2 (also TD5). I had put it down to the recently fitted roof rack but found that it goes away over 60mph. No discernable vibration through the steering wheel. Will investigate later and report back in case it helps diagnose yours. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #1070740 3rd Jul 2025 11:14am
camelman
After changing the n/s front wheel bearings (where it appeared the noise was coming from), there was no change. I then swapped the o/s as I was on a roll and the problem has gone!
Post #1071025 8th Jul 2025 2:01pm
