Home > In Car Electronics > Loose cable behind stereo?
roche1800
Hi, I am not sure if I have managed to dislodge this cable while installing a RCA cable from rear member
for a reverse camera.
It’s white with black sleeve and seems thicker than any other wires!
Here’s a photo
Post #1068294 22nd May 2025 6:00pm
roche1800
It’s a 2014 crewcab.
Post #1068295 22nd May 2025 6:01pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
That looks like a coaxial cable - if it is it has a central conductor and is surrounded by a thin braided wire sheath. Typically used for an antenna or a AV cable. Can you follow the cabe to see where it goes? It doesn't look 'factory'.
Post #1068322 23rd May 2025 9:53am
roche1800
Here are a few more pics… 🤷🏼‍♂️
Post #1068412 25th May 2025 3:27pm
That does indeed look like Coax cable, typically some kind of antenna cable. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1068425 25th May 2025 5:24pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Is it not the aerial for the alarm remote?
Mine has a similar wire there.
Post #1068444 25th May 2025 10:15pm
Scotm
In fact you can see it in this picture from when I changed the wiper spindles earlier in the year.
Post #1068445 25th May 2025 10:19pm
On a 2014 it probably is the alarm aerial. The obvious suggestion is for the OP to trace the other end of the wire and see what is connected.
Post #1068448 26th May 2025 12:23am
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Here's a link to a post about extending the remote aerial cable to extend the central locking range.
It certainly looks like the identical white cable & it appears the end of the cable would originally have been connected to a clip under the dash.
https://defender90xs.blogspot.com/2014/11/...nsion.html
Post #1068452 26th May 2025 6:28am
Martin
Site Admin
https://www.defender2.net/forum/topic87569...white+wire  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1068454 26th May 2025 8:22am
