![]() | Home > In Car Electronics > Loose cable behind stereo? |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 412 ![]() |
It’s a 2014 crewcab.
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 393 ![]() ![]() ![]() |
That looks like a coaxial cable - if it is it has a central conductor and is surrounded by a thin braided wire sheath. Typically used for an antenna or a AV cable. Can you follow the cabe to see where it goes? It doesn't look 'factory'.
Here are a few more pics… 🤷🏼♂️
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
That does indeed look like Coax cable, typically some kind of antenna cable. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 691 ![]() ![]() ![]() |
Is it not the aerial for the alarm remote?
Mine has a similar wire there. |
In fact you can see it in this picture from when I changed the wiper spindles earlier in the year.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
On a 2014 it probably is the alarm aerial. The obvious suggestion is for the OP to trace the other end of the wire and see what is connected.
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 344 ![]() ![]() ![]() |
Here's a link to a post about extending the remote aerial cable to extend the central locking range.
It certainly looks like the identical white cable & it appears the end of the cable would originally have been connected to a clip under the dash. https://defender90xs.blogspot.com/2014/11/...nsion.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic87569...white+wire
