Home > Puma (Tdci) > Diesel Runaway Help please
Page 2 of 2 <12
Ianh
Sam smith wrote:
okay thank you, the actuator should be movable by hand i am assuming?
With the circlip off the linkage should be so loose it feels like it’s disconnected
https://www.defender2.net/forum/post853115.html#853115
Post #1068187 20th May 2025 9:58pm
Sam smith
United Kingdom 2009 Defender 110 Puma 2.4 HT Epsom Green
hank wrote:
I had this happen in France. It was in injector. One of the injector solenoids had jammed open injecting masses of fuel into the engine.
That amount of oil in the intake pipework is not uncommon and is just downstream of the PCV return which suggests crankcase pressure.
Test the resistance of each injector and see whether any one seems out compared with the others
Thank you for the suggestion, i will look at this at the weekend. It made the diesel runaway happen for you as well?
Post #1068188 20th May 2025 10:07pm
landy andy
What colour was the smoke?
Smell?
Post #1068189 20th May 2025 10:11pm
Ianh wrote:
I suspect it’s a faulty turbo actuator , or linkage to actuator sticking fully open when engine was running.
I think Blackwolf had something similar on his 2.4 a while back.
Interesting you have no DTC’s.
I doubt it is a faulty actuator, the engine would still respond to the throttle and would stop on the key if the actuator stuck on full boost.
In the absence of loads of oil in the intercooler my suspicion is a failed injector.
Post #1068193 20th May 2025 11:09pm
landy andy
If failed injector, by which I assume stuck open, can this only happen with an engine that doesn’t have an electric fuel pump, or will it suck fuel through regardless?
I also assume that runaway due to a single failed injector is more likely to cause engine problems due to only a single cylinder getting overdosed with fuel?
Or this where the injector or injectors have been overdosing fuel, to a point that the engine is runs on its own oil due to it being massively overloaded with fuel (diesel)?
Post #1068200 21st May 2025 9:09am
andy63
It was a long time ago but I've known of two engines that ran away on oil vapours from failed turbos..
Both disappeared in a cloud and both self destructed 😫but as i said don't know the full details ..
Neither would have had throttle bodies , so I'm curious in your case how the engine reacted to you switching it off.. was there any tendency to stop or not.. and how did you get it stalled..a full run away i imagine is frightening.. and usually terminal..
Ive had an engine do it briefly while been a bit over generous with brake cleaner on a sensor in the intake hose , and turning the key before the vapours cleared 😳🤣..it ran on even after switching off and i think that engine had a throttle body , but not sure if it was a mapped engine and maby not active..
Post #1068202 21st May 2025 9:16am
Sam smith
Smell?
I have ohms checked the injectors all reading 0.5Ω but i have 2 injectors in my parts bin that i know to be faulty that also have the same reading so either my multimeters are faulty or arent good enough to check them in this way? is there another method? i had all injectors professionally tested and had to replace 2 with the other 2 being okay at the end of 2024 so i would have thought they wouldnt have died that quickly?
Post #1068245 21st May 2025 8:51pm
andy63
Checking the resistance of your injectors is really only a quick first check..
I'm guessing that you have solenoid type injectors as the piezo would measure into the kohms..
The only way to check them properly is under load as loaded they may break down at the higher voltages applied and the initial high current..
They could also be defective mechanically ..ie sticking but still electrically OK..
For the likes of us DIY type mechanics the best tool for that job is a scope to check the electrical side..
I asked a couple questions above.. ie does your engine have a throttle body.. did it make any difference when it ran away when you switched off..
Did it actually run away uncontrollably or did the revs just rise to a much higher level for a time?
Post #1068262 22nd May 2025 8:05am
Dinnu
^^^ 2.4s do not have a throttle body. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1068270 22nd May 2025 8:54am
andy63
Thanks.. i only know the 2.2, and even that's debatable👍🤣
I was starting to wonder if my queries would get answered..I recall recent threads on glow plugs and turbo actuators where the poster didn't reply to queries..
It's a shame because it's nice to get a conclusions or as much information on someone's issue.. it all helps ..
Ta..
Post #1068271 22nd May 2025 10:08am
Page 2 of 2 <12
