![]() | Home > Puma (Tdci) > Diesel Runaway Help please |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2468 ![]() ![]() |
With the circlip off the linkage should be so loose it feels like it’s disconnected https://www.defender2.net/forum/post853115.html#853115 |
Sam smith Member Since: 12 Aug 2021 Location: Suffolk Posts: 79 ![]() ![]() ![]() |
Thank you for the suggestion, i will look at this at the weekend. It made the diesel runaway happen for you as well? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
What colour was the smoke?
Smell? |
If failed injector, by which I assume stuck open, can this only happen with an engine that doesn’t have an electric fuel pump, or will it suck fuel through regardless?
I also assume that runaway due to a single failed injector is more likely to cause engine problems due to only a single cylinder getting overdosed with fuel? Or this where the injector or injectors have been overdosing fuel, to a point that the engine is runs on its own oil due to it being massively overloaded with fuel (diesel)? |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 815 ![]() ![]() |
It was a long time ago but I've known of two engines that ran away on oil vapours from failed turbos..
Both disappeared in a cloud and both self destructed 😫but as i said don't know the full details .. Neither would have had throttle bodies , so I'm curious in your case how the engine reacted to you switching it off.. was there any tendency to stop or not.. and how did you get it stalled..a full run away i imagine is frightening.. and usually terminal.. Ive had an engine do it briefly while been a bit over generous with brake cleaner on a sensor in the intake hose , and turning the key before the vapours cleared 😳🤣..it ran on even after switching off and i think that engine had a throttle body , but not sure if it was a mapped engine and maby not active.. |
I have ohms checked the injectors all reading 0.5Ω but i have 2 injectors in my parts bin that i know to be faulty that also have the same reading so either my multimeters are faulty or arent good enough to check them in this way? is there another method? i had all injectors professionally tested and had to replace 2 with the other 2 being okay at the end of 2024 so i would have thought they wouldnt have died that quickly? |
Checking the resistance of your injectors is really only a quick first check..
I'm guessing that you have solenoid type injectors as the piezo would measure into the kohms.. The only way to check them properly is under load as loaded they may break down at the higher voltages applied and the initial high current.. They could also be defective mechanically ..ie sticking but still electrically OK.. For the likes of us DIY type mechanics the best tool for that job is a scope to check the electrical side.. I asked a couple questions above.. ie does your engine have a throttle body.. did it make any difference when it ran away when you switched off.. Did it actually run away uncontrollably or did the revs just rise to a much higher level for a time? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
^^^ 2.4s do not have a throttle body. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Thanks.. i only know the 2.2, and even that's debatable👍🤣
I was starting to wonder if my queries would get answered..I recall recent threads on glow plugs and turbo actuators where the poster didn't reply to queries.. It's a shame because it's nice to get a conclusions or as much information on someone's issue.. it all helps .. Ta.. |
