Home > Puma (Tdci) > Is this OK - Rear Differential Backlash
Andy344590
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Indus Silver
2014 90 Puma 2.2 - I replaced the halfshafts for LOF solid and found a lot of debris in the hub (https://www.defender2.net/forum/topic95141.html), so following forum advice i have just changed the wheel bearings.
When refitting the hub i checked the backlash in the diff as part of 'the clunk' chasing and felt approx 5-6mm of backlash in the rear differential, which may be normal, but got me wondering if this is OK. What are your thoughts on this.
The handbrake was on and I checked there was no movement in the propshafts when marking the disc
Post #1067423 10th May 2025 6:32am
landy andy
It’s difficult to say that way but I certainly wouldn’t be overly concerned with what you have. You would be better off testing your diff backlash with wheels on the ground and turning the diff input.
Post #1067424 10th May 2025 7:18am
Andy344590
Thanks Landy Andy, I will see what it like using that method. Stilll learning about 90, probably will be for a long time yet Smile
Post #1067431 10th May 2025 9:22am
You always get some backlash, I seem to recall anything over about 10 degrees is a concern.
But don’t quote me exactly on that, it’s worth checking wheel bearings as well for any horizontal or vertical play while you are there.
I wouldn’t worry too much personally. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067440 10th May 2025 1:59pm
Accidental double post* ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067442 10th May 2025 2:47pm
